Hi everyone, i was wondering if i should bother making or buying some type of tool to screw the piston back in. I have a six inch c clamp hehe but that didnt really work too good , then i looked on here and found out that i need that screw tool. So should i just rig something up to apply presure to the piston then turn or is the tool actually really cheap?
#2 | |
Member of the 20 nut club
Harbor Freight Tools - Quality Tools at the Lowest Prices
you might be able to find them for rent or purchase from a local parts store or you can find a snapon or mac tools truck and pay out the fucking ass for a set __________________
МОΛΏΝ ΛΑΒΈ |
Running on two cylinders
Ride: 2000 Mitsubishi Lancer RPW E5 Coupe
when i did them on my old hatch i used the combination of a thin steel file and a very large tipped standard screwdriver. took a little while but worked like a charm!
Home of the RPW built 2000 Lancer CC Coupe. See what is done to the little Evo5. "If you don't like what I've done with my car, I will gladly refund all the money you put into it." |
Admin with a big stick
Ride: 2003 S2000
Buy aftermarket 2 piston fixed calipers. No piston screw back in issues. It's an expensive solution though.
![]() __________________
#5 | |
Blah blah blah....
I just use a pair of cheap needle nose pliers. works well, and quick.
#6 | |
Ride: 93 del Sol Gas sipper
If you already tried a c-clamp, you may have already fucked up the caliper. __________________
Collin Material Science and Engineering Michigan Technological University |
| WTB..94+ integra rear brake bracket | Hondatuner88 | Parts: For Sale/Trade/Wanted | 0 | 01-15-2006 03:57 PM |
| Rear disc brake conversion for 96-00 civic | Autozoner n civic owner | Wheels / Suspension / Tires / Brakes | 4 | 12-08-2005 12:26 PM |
| Rear Disc Brake Conversion For 90' Crx Hf | hardweapon | Wheels / Suspension / Tires / Brakes | 5 | 03-01-2003 03:40 PM |
| 5g Rear Brake Conversion | Distorted | Wheels / Suspension / Tires / Brakes | 4 | 01-13-2003 01:48 PM |
| civic to GSR brake upgrade (front & rear) | slowasscx | Wheels / Suspension / Tires / Brakes | 11 | 01-08-2003 04:18 PM |
