Rear disc brake conversion for 96-00 civic
Old 11-30-2005, 09:59 PM   #1
Rep Power: 9 Autozoner n civic owner is off the scale
Has anyone done a disc brake conversion from drums with the si brake componets on 96-00 civics? I know I need to get the rotors, calipers, caliper mounting brackets, hub/bearing assembley, and splash guards for each rotor. but do i need to change the hydraulic lines to make it compatible with the calipers? also, is the e-brake cable compatible with the si rear calipers as well? if anyone could offer any insight, that would be great.
Autozoner n civic owner is offline   Reply With Quote
Old 11-30-2005, 10:29 PM   #2
Rep Power: 59 hcivic.com is on a distinguished road
you only need to post once, and do a search first
hcivic.com is offline   Reply With Quote
Old 11-30-2005, 10:53 PM   #3
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Yes, you need to change the lines... plus you'll want to get the e-brake cables from the Si too.
Old 12-06-2005, 02:28 PM   #4
this is part of my search, i've tried to figure this out, but I do not have an si to look at. Sorry, I posted in the wrong place first.
Old 12-08-2005, 12:26 PM   #5
PLA5151's Avatar
Ride:  H22A EJ7, '90 Yamaha FZR600
Rep Power: 11 PLA5151 is on a distinguished road
<div class='quotetop'>QUOTE(Autozoner n civic owner @ Nov 30 2005, 06:59 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
I own a '96 civic coupe hx and i used the rears off a gsr (98 I think??) and i was able to use everything except the lower control arms which i had to use my original hx lower arms, gsr e-brake cables or si will work OK, I also opted to replace the master cylinder because it holds more fluid and my vacuum booster because it came with it. You will have to replace the proportioning valve as well.
Body: '96 Civic HX coupe
Heart
H22A
Brain: stock P13
Mods:
----aem v2 cai
----exedy organic clutch
----act 8 lb flywheel
----rmf 4-1 header
----rs-r gt II exhaust
----optima battery
PLA5151 is offline   Reply With Quote
