This is a discussion on rear disk in the Wheels / Suspension / Tires / Brakes forum
i want to do the rear disk conversion on my ef. i want to know if i can keep my stock prop valve, booster and master cylinder and just change out the rear trailing arm bushing. thanks in advance for any help...
| | #1 |
| i want to do the rear disk conversion on my ef. i want to know if i can keep my stock prop valve, booster and master cylinder and just change out the rear trailing arm bushing. thanks in advance for any help |
| | #2 |
| Not sure how the changing your rear trailing arm bushings will give u disk conversion. Ha ha if u have a 40/40 proportioning valve. (And I think u do.) It will work. Your master cylinder Should be fine. I used a Integra rs master. You need the whole rear trailing arm and brakes. Also if you never took your rear lower control armsu off beforethe you will probably need all new bolts (6 or 8 bolts I think) and possibly new lower control arm due to the bushings ripping. I think that's it. Last edited by Dagnasty EF; 07-23-2011 at 12:26 PM. |
| | #3 |
| shoulda worded tht better lol i just didnt know if i needed the prop valve from say a da teggy when i take the rear disk off it or if i could keep my stock one |
Similar Threads | ||||
| Rear disk brakes on an 87 | decepticon | Accord | 5 | 02-18-2009 07:27 PM |
| rear disk | Reckone | Civic and CRX - EF | 0 | 03-21-2007 11:16 PM |
| 94 hatch rear disk? | civicjunky | Civic and del Sol - EG and EK | 15 | 10-14-2006 06:58 PM |
| Need Help on Rear Disk Swap on an EF. | ef9civicgen4 | Wheels / Suspension / Tires / Brakes | 5 | 01-07-2006 04:53 PM |
| rear disk | 93civicsir | HYBRID -> ED-EF / DA | 9 | 12-10-2005 09:59 PM |
