d16a6/d16y8 "mini-me"
Ride: 1990 Honda Civic Si
Hey guys, I looked around for the most appropriate area to post this thread. Please don't get mad if I posted in the wrong area. I have a steering column issue. The story is; I took out my dash to put a new cabin wiring harness on the inside of the firewall because my old one was hacked. So I decided I would take the whole steering column out because it was just in the way and got kind of annoying at some points. First off, I admit, I did not mark where the steering column splines go in conjunction with the steering box (so I am in for an annoyance at my own stupidness). I believe it is the steering box, please correct me if I'm wrong! I went to put the bolt into the steering box and through the steering column splines so to speak. It was a little hard to bolt in, but I figured it had to be considering it is a huge safety concern if it isn't. I ended up turning the bolt too hard and figured it was stripping so I looked and sure enough it was stripping. This wasn't the kind of stripping that you enjoy either. I don't know what to do now. I figure as of yet; 1) I'm going to have to call my local Honda dealer parts guy to see if he can get that bolt in, and 2) I am going to have to tap the hole out to make the threads nice and "new". I hope you can gather something from this novel I wrote. Thanks guys, any help is appreciated!!
D16a6/D16y8 Build ![]() 75.5mm Overbore D16a6 Block Rebuilt (by me) Contemplating a "Stage 2" D16y8 Head Rebuild D16y8 Thin Headgasket Vision 5-Way Adjustable Cam Gear "To learn anything in life, keep your mouth closed and ears open" |
Running on two cylinders
Ride: 2000 Mitsubishi Lancer RPW E5 Coupe
you could always drill it out and put a nut on the end
Home of the RPW built 2000 Lancer CC Coupe. See what is done to the little Evo5. "If you don't like what I've done with my car, I will gladly refund all the money you put into it." |
Thanks for the suggestion, however, would that still be considered safe?
i dont see why not.
#5 |
Ride: 91 civic hatch w/b16 and 91 civic hatch project car
are you talking about the u-joint at the bottom of the column where it goes through the floor? I believe they only go on one way, I think there is a grove on the shaft coming from the rack. Did you try and remove the bolt?
#6 |
Yes, that's the one. It goes through the "U-Joint" and locks the steering column. I will have to check to see if it has a spline that only allows for one way installation. I already had it in once, but maybe I got lucky. The reason I think putting a nut and bolt would sacrifice safety is because I have worked in a lot of factories and know that where there is paint from the manufacturer, it is a huge safety factor and those markings are for the inspection that the government conducts.
#7 |
it shouldnt be a safety issure the steering column is bolted to the firewall. If the nut and bolt hold the u-joint closed it shouldnt slip on the gear box.
#8 |
Thanks or all the input so far. I will seriously consider drilling it out and placing a nut and bolt in its spot.
| Honda Civic 1992-1995 EG Steering Column: horn pads, steering wheel, air bag and more | master23 | Civic and del Sol - EG and EK | 0 | 06-24-2009 09:42 PM |
| stripped tensioner bolt hole | Sn0rKy | Engine Building | 8 | 08-17-2006 02:48 AM |
| Stripped tranny bolt? | LsB16CrxHF | HYBRID -> ED-EF / DA | 6 | 03-22-2005 10:24 PM |
| Stripped bolt | mwvnos | General Tech and Maintenance | 11 | 12-14-2003 03:45 AM |
| Stripped Head Bolt | Sed8ed | Engine Building | 4 | 05-13-2003 02:30 AM |
