Sway bars
Old 02-17-2008, 12:33 AM   #1
Regular Member w/ Cheese
YBLEGAL's Avatar
Ride:  2000 EJ8 w/ SiR-II
YBLEGAL has a brilliant future
myspace
Default Sway bars
I've got a 2000 Civic EX. I'm looking for sway bar options. I don't have a rear sway bar from the factory. What should I be looking for? ITR front sway bar? What size mm. Endlinks required? Any special brackets? I've read some chassis needing ones from summit. I'll get energy suspension polyurethane bushings. Not much info for my EJ8. Any help appriciated!
Old 02-19-2008, 02:49 PM   #2
B
Administrator
B's Avatar
Ride:  2010 Hyundai Genesis Coupe 2.0t Track Edition, 2000 Dakota
B has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond repute
B has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond repute
myspace  FaceBook
don't buy a front sway bar. you'll under steer into oblivion.
if you go itr, you need itr lca's, which then means you need itr-style shocks.
ideally, you want something like this:
so it doesn't tear out your subframe
B is offline   Reply With Quote
Old 02-19-2008, 02:59 PM   #3
YBLEGAL's Avatar
myspace
What's ment by ITR-style shocks?
I've got Omni rear lower control arms. Would these be compatable?
but honestly if i'd have to change the dampers and springs out, i'm not going to buy this now since i just temporarily got some s-techs on it. but for my future information...
thanks
Old 02-19-2008, 03:56 PM   #4
B
Administrator
B's Avatar
myspace  FaceBook
nope.
itr lcas and shocks sit in the lca, not wrap around.
Old 02-19-2008, 04:25 PM   #5
Führer Mod
eg6sir's Avatar
Ride:  Le Car
eg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
Send a message via AIM to eg6sir Send a message via Yahoo to eg6sir myspace  FaceBook
ITR rear sway bar will still bolt up to different LCAs.. as long as it has a mounting point.. but a subframe brace is recommended to prevent tearout
eg6sir is offline   Reply With Quote
Old 02-19-2008, 04:56 PM   #6
YBLEGAL's Avatar
myspace
oh wow. ok, i never knew that about itr lca's. but i have read about the benifits of something like the ASR subbrace.
alright, well i thought that could solve my roll situation some. i got an OEM strut tower bar for the front, the s-tech teins, oem dampers, and a buddy club front/real camber kit.
i plan on getting a tein flex setup in a couple years, when the motor gets better. I might consider changing to the integra rear suspension setup then, but it would be too much now.
anything else i could do to minimize roll?
Old 02-20-2008, 01:30 PM   #7
B
Administrator
B's Avatar
myspace  FaceBook
the shocks will be the biggest improvement.
Old 02-27-2008, 03:26 AM   #8
|Chaz|'s Avatar
Ride:  92' EG Sedan
|Chaz| has a reputation beyond repute
|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute
Send a message via AIM to |Chaz| Send a message via MSN to |Chaz| Send a message via Yahoo to |Chaz|
Wow that's interesting to know about not needing a front sway bar, I always just assumed that they'd improve the handling. But the understeering thing makes sense when I think about it though.
|Chaz| is offline   Reply With Quote
Which sway bars do i get chris124816 Wheels / Suspension / Tires / Brakes 1 09-18-2007 06:15 PM
zc swap into 85 crx? devnjeff HYBRID -> ED-EF / DA 4 07-10-2005 10:09 PM
1st Gen CRX FAQ's pissedoffsol Swap Articles 0 01-12-2004 12:51 AM
Education FirstAccord Wheels / Suspension / Tires / Brakes 13 06-16-2003 04:03 PM
Sway Bars In Hatch CivOnDubs Wheels / Suspension / Tires / Brakes 1 02-24-2003 12:34 AM
