What's better in brakes?
Old 08-22-2003, 12:50 PM   #1
ovcrash is off the scale
What's better in brakes? Slotted rotors? or Drilled rotors? or Slotted/Drill rotors?
Whats would be the best?
ovcrash is offline   Reply With Quote
Old 08-22-2003, 12:53 PM   #2
B16
B16's Avatar
B16 has a reputation beyond repute
B16 has a reputation beyond reputeB16 has a reputation beyond reputeB16 has a reputation beyond reputeB16 has a reputation beyond reputeB16 has a reputation beyond reputeB16 has a reputation beyond reputeB16 has a reputation beyond reputeB16 has a reputation beyond reputeB16 has a reputation beyond repute
Send a message via ICQ to B16 Send a message via AIM to B16 Send a message via MSN to B16  FaceBook
neither, autozone $20 rotors or brembo blanks. no need for slotted/drilled unless you're doing LeMans racing, hehe
Old 08-22-2003, 12:55 PM   #3
liquid00meth is off the scale
Send a message via AIM to liquid00meth
the biggest blank disc you can afford
liquid00meth is offline   Reply With Quote
Old 08-22-2003, 12:59 PM   #4
But i have Blank Brembo brakes in the front and last time i was racing a 99 Accord and i slammed on the brakes because stupid people don't get out of the way...and i was doing 180Km/h and the brakes responded good but in the end i had no more and my brakes are new..i guess they got fucking hot and did not work good when they got at that temperature..so that's why i'm looking into maybe drilled, or slotted..?
Old 08-22-2003, 01:01 PM   #5
B16
B16's Avatar
then you just need better pads, get either hawk hps or hp+
Old 08-22-2003, 01:04 PM   #6
Then it's my pads that got to hot? nothing to do witn my disk?
Old 08-22-2003, 04:34 PM   #7
deth101 is off the scale
Send a message via MSN to deth101 Send a message via Yahoo to deth101
the friction and heat of both....if you get em that hot often look into some fender fins for cooling.still have too much heat,then I would go w/slotted olny and pads the maker recommends.drilled wont last as long on the street,might crack over time.your wheels might also be restricting airflow to them....mostly I mean hubcaps.take em off if you have em.
improving your airflow is key regardless of your choice,it will show improvements regardless of type of rotors/pads
deth101 is offline   Reply With Quote
Old 08-22-2003, 05:02 PM   #8
B16
B16's Avatar
certain pads only produce certain coefficents of friction at given heat levels. performance pads will list this in detail for you. go to
http://www.hawkperformance.com and check out the characteristics of the pads, the pads will always get hot, what matters is how much friction they still produce at certain temps. but, you also dont want a straight race pad that only starts working once they are above 300deg, which means you wont be able to stop cold.
prelude brakes on accord dtaila HYBRID -> BA-BB /CA-CD 1 03-20-2004 09:44 PM
Brakes KyleCrews Wheels / Suspension / Tires / Brakes 10 06-20-2003 10:05 AM
Civic Sir Brakes IceBolt Wheels / Suspension / Tires / Brakes 1 04-19-2003 05:50 PM
Hf Brakes? stud4u2c17 General Tech and Maintenance 1 03-04-2003 01:02 PM
Big Brakes Slimtadder Wheels / Suspension / Tires / Brakes 2 10-14-2002 01:23 AM
