help with engine swap
ilikehondas
hey, i own a 93 EG civic hatch and im looking to do an engine swap, i have been looking at a b16a though reading some of the topics i am wondering if other engines are more owrth it eg. k20 or b18??
any help?
yea you got the b16 or the b18(gsr) which they are both gonna be about the same prolly price wise but do research on what you can do most with or what your goals are
im pretty sure b18's run more expensive than b16's
my goal is pretty much to get another engine, the d15 i got in there ( i think its a d15 or some other shit) is on its way out, body is in great cond. where can i read up on engine swaps??
dude if the d-series in question is low on miles JUST BUILD AND BOOST!
not if its a b18 ls or gsr compared to a ek type r b16b. hell the usdm gsr isn't that much better than the jdm b16a sirII. but yes the more expensive engines tend to be b18's.
also a b18c1 (gsr) is going to be a lot more expensive than any version of the b16a. at hmotors you can purchase a b16 anywhere from 1450-1800. jsm gsr will run ya $2,600! prices are for motor, trans, and ecu.
to the op: if the engine you have is in decent shape and you want to consider turbocharging it, that would not be a bad route to go. of course i would run a good bit more than 6-8 psi on it if you intend on being able to keep up with b18 swapped vehicles. if you don't feel like building the d, then swapping it out and dropping a b in, is another good choice.
:werd: yeah my b16b ran me about 1500 bucks tranny and all
$1,500 for a b16b! Did you mistype something...
thats why i said the gsr
B18C 94-97 (GSR) Complete Change Over
Price: $ 2899.00 Plus shipping and handling.
Availability: In stock and ready to go.
- Motor
- Hydraulic Tranny (S80, Y80)
- ECU (P72)
- Axles with Half Shaft
- Shift Linkage
- Stock Motor Mounts *
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Comes With All Sensors Needed
- LSD Tranny (Optional +$350)​
My first swap was B16a in 93 hatch. It's a simple swap fpr the most part. It will be fun for a while, but you will find yourself not happy later on. I should'nt say that. really it depends on what your goals are. Figure that out first. You mentioned the K20? I performed this swap also. I'm very happy with it right now. It is more expensive, but well worth the value. K20Z swap and little extra(not much you got a low 12 high 11 second car.
oh shit my bad forgot to mention got it out of an old track car from my local shop and i know the owner pretty well so she gave me an enourmous deal ha ha sorry guys:bonk:
i think it might be a d13 engine, googled it this arfternoon.
will probably go with a b16a swap, then turbo and hopefully spoon parts
Spoon parts? Yeah, ok. Make sure you throw a MoTec system exhaust on there too...and Mushimoto ZX tires...
yeh dude spoon, im sure you that you gotta know spoon sports.
looked at that exhuast system, and listened to it on youtube ahah pretty hectic
