you only need the gsr intake cam, the exhaust cams are the same for all b series vtec engines (except type R I think)
Get a set of cam gears too, they will also help out with the "tuning"
Be careful, SOME B16a engines from automatic cars have only valve single springs on the intake and exhaust sides, DO NOT USE GSR CAMS if your engine doesn't have dual valve springs (1 inside the other) otherwise you will break retainers or valve springs with the higher lift GSR cams, either way it'll be a bad day. It is easy to take a look and see if you see a smaller spring inside the larger outer springs.
