Dysturbed_90dx_4dr
I own a 1990 Honda Civic DX Sedan (I have a D16A6 sitting in the garage for it just buiding it up before it gets dropped in.). This car feels really loose when cornering and in general driving conditions. I wanted to beef it up a bit before the swap on a budget but I am not really sure where i can go with it. Will the hatch or CRX front sway bar fit it? I know it doen't have a rear, I have heard rumors about being able to swap (some year) Integra Rear parts to allow you to use a Integra rear sway bar. Also the rear rotors obviously i have heard about. Any other ideas that would be good.
For a daily driver would you recommend KYB struts or would you go with something else? I am considering Eibach Pro-Kit lowering springs so i won't be a extreme drop. I am also going with 15" rims so they won't be too big either.
Basicly I want to stiffen the car up so it's more enjoyable to drive rather than feeling like you are driving on a dirt road on the interstate. I am in process of replacing the tie rods and ball joints as well as the front axles (dont ever buy refurbished axels i have had lots of bad experience with thie car)
Would the Prothane or Energy Suspension kits help me out any i know alot of my bushings are wearing a little thin and I am going to probably need to replace alot of them. If not then should i at least get a poly trailing arm bushing?
Thanks for any help in advance,
If you need to talk to me directly my im: DysturbedCRX
Thanks Again,
Dysturbed
Thanks Again,
Dysturbed
