Bad little allmotor Ls/Vtec build!!
boostin4fun
Boosted ls/vtec ohh yeah!
Well this has been a little on going project that im doing for a friend. I thought what the hell I havent showed the rest of the world my work!! So I thought I would start this thread and add to it as this project comes to a end in the next 5 to 6 weeks. But this is where the project stands of right now. I will list the parts of the build and then pictures of the build itself and the car.
Engine
Shortblock
B18A block bored and honed .20 over
LS crankshaft micropolished and balanced
SRP forged pistons .20 over 10.4:1 with b16 head
Eagle LS rods ESP H-Beams, Overkill yes but thats the way I like it!!
ACL Race bearings, check clearances and all good.
New type R oil and water pumps.
Of course all new seals and gaskets are OEM Honda
CTR crank pully, yes i know the picture shows the gay old one, i will swap it soon.
Head
B16 head of 2000 civic si
Fresh valve job with OEM Honda seals
Skunk2 dual valve springs
Skunk2 Titanium retainers
Skunk2 Stage2 Camshafts
Skunk2 Camgears.
Brand new Integra type R lost motion assemblies, Yes im very thorough!!
Valve cover was cut, blasted, and chromed!!
Greddy Extreme timing belt
AEM fuel rail and pressure regulator
RC 310cc injectors
Brand new obd1 distributor
Edelbrock 65mm type r throttle body
Transmission
2000 civic si b16 vtec transmission
Quaife LSD, I will post up pics of it and the install when it gets here.
Exedy Stage1 Race clutch
Exedy lightened flywheel
Other pieces
Hasport hydraulic mount kit for crx
Hasport shiftlinkage
Integra rear disc conversion, not yet installed but will post pics
Tokico blues
Tanabe grip force lowering springs
camber kit on all 4 corners
obd0-0bd1 conversion harness
p28 chipped ecu, awaiting my tune with CROME Pro.
Im sure there is more i am forgetting but i will post it up when it comes to me Every part on this build was brand NEW thats the way i do things, with the exception of the block, crank, and head which were all reconditioned to say the least.
This is the picture of the car, yes it is far away sort of but it is the only one i have right now.
The old engine before removal and after.
The engine bay was not painted when the rest of the car was, but we are going to take care of that. Here is the engine bay, gutted for the most part. And a shot of the frame rail where it is knocked back to clear the alternator pully according to Hasport's instructions. It had been spraypainted black to cover up the red inside, so we had to sand all of that shit off. We are going to seal and paint it soon, i will post up pics of it.
Now some pics of the bottom end.
More pics of the bottom end.
I doubt it, see my friend does paint and body work and this was a decision he made when he was 16 to put the kit on. He is now 21 and probably wouldnt have made that decision now a days, but its a little late now. The car wont really be on the track. It is just going to mainly be a spirited daily driver. He will most likely just drive it on the weekends. At least the kit was reinforced and done right compared to 95% of all the other cars i see.
Some pics of the head. I cant find any of the pics of the cams :( .
A few pics with a little more assembled.
Well thats all for now. Currently waiting on the quaife to get here. I will post pics of that install. Also waiting to finish painting the engine bay but that should be done by this weekend. I will be working on the wiring. I have to do the dpfi to mpfi conversion and then the obd1 conversion shit, but thats no biggie. I will definetly keep updating this thread as the build continues. Hell if i feel real ambitious i will post up my boosted ls/vtec build in my si with the $10,000 worth of goodies it has!!
Is this a race dedicated engine? If not those ACL Race bearings are going to be a longevity problem, according to Earl Laskey (r.i..p) and Benson's Machine shop anyway.
is that a honda only thing? 3 of my friends have built small blocks (ford and chevy) all three are running ACL bearings (actually i think after writing that, one of them is running clevite). None have under 20k miles, one has gone up to 48k. Now if you mean longevity past that, i cant say for sure, i can just say that weve only pulled one of those motors since it was dropped, and that was a blown head gasket (the ford of course).
any ways, looks sick man. if yall get it to the track let us know how it does. make sure you get some tuning time in on that baby. itd be sad to see all the money wasted.
The Race Bearings are not any bigger then their standard duraglide bearings, unless you order them that way. I have the standard set, not .01 bigger, that would make absolutely no sense for them to sell them that way. No one's clearances would pan out without having the crank machined.
But anyways yes this thing will be tuned out right away. I use the moate's ostrich and CROME Pro, with LM-1 wideband. No sense in building it if its not going to run right, huh!!
just makin sure. a buncha people think building a honda is like building a carbed SBC....and the moment they realize its not, they usually have a connecting rod hanging out of the block.
I know exactly what you are talking about, lol!! They buy thousands of dollars worth of parts and build a highly modified engine. Then they run the factory ecu and scratch their heads when it runs like shit and blows up shortly after! You should of seen this dumbass I bumped into the other day. He's talking about how he knows so much more then me, and that his car will be faster and so on. He has a stock internal b16 with a huge t4 turbo, 900cc injectors, and a emanage ultimate. The car cant even come close to running right. I told him he had way too much turbo and injector, but hey what do I know! I asked him if he knew what a wideband was and he gave me a funny look, thats when i ended the conversation.
been there....there arent a whole lot of intelligent honda guys to talk to in dallas. and when you do find one.....hes selling his honda. its a sad but true reality.
Yeah i dont have alot of intelligent people to BS with anymore either. Thats why I like to come one here and talk to people. Not everyone knows alot but there are alot of smart people on here.
