d16z6 swap
Z6CRX
übber ɐɾuıu etarip
can i put a d16z6 transmission on a d15b7 engine
WTF start your own thread and read the FAQ section.. its in there.
the answer in short is yes. though. its a hydraulic transmission. So if you are running a hydraulic one now you should be fine. otherwise its not as easy.
92CIVIC4DR
sorry i didnt know how to post but they are both hydraulic trannys, so they will bolt straight across?
boostfreak 417
i have a bad ass ohm meter from universal technical institute. everything i test im getting power too. can you tell me the main things i should test, i just want to see if ive missed anything important
mesa50w
I had pretty much the same problem on my ef z6 swap. Mine turned out the Locash harness i got had 2 igniton wires crossed and missing another ignition wire...buy it used on a forum so:( But here did you get your ecu pinout info from?
Z6CRX
übber ɐɾuıu etarip
everything from the ecu to the engine for the most part.
Go sensor wire by sensor wire.
There should be a wiring diagram in the back of any manual, you need to get one thats meant for OBD1, you can even find this in our faq section. You can find the ECU pinout in the FAQ section.
