4 lug conversion...?
all DA's are 4 lug (90-93 Integra)
I just want to know if anyone has/knows if the trailing arms will bolt up.
I know DC's bolt in, and to answer Doug810's question any drum to disc swap in an EG you need the trailing arms and ebrake cables to start with. Its a good idea to get a 40/40 proportioning valve (non-ABS DC's, its stamped on the valve) to distribute the fluid correctly. Some people also change the master cylinder and brake booster, but thats not totally nessecary. Most people also change the rear lower control arms , but again, thats not totally nessecary...
