ek computer question
  • Thread starter Thread starter keg
  • Replies Replies 8
  • Views Views 1K
keg
:( hi im in a spot of bother my 96 ek with a d13b has a computer code p2a? cant seem to find it anywhere on here, we are putting in a b20b and need to know what i have to change on the harness and ecu please help[
i have a 96 ek also i am in the process of swapping in a b18b ls motor. iam using a stock p75 ecu out of a 96 integra. it will plug right in the same sockets as your old one. all you prob need to do as far as wiring is extend both o2 sensors and switch out a couple plugs and your done
so even though it is a p2a? which i havnt been able to find will a ls ecu plug into it and run the b20 is the dizzy plug the same?:mellow:also is there any link to tell me or show me which plugs to change
what year b20 are you putting in. if your car is obd2 and the motor is obd2 then evrything will fit except the cfs sensor and then 02 sensors are to short you neeed to extend them. what year is your car and is it a dx cx lx ex
it should all plug in the same as the ls swap in your . what make and model is your car
ive been offered a gen 2 vtec head what ecu will plug into that and what changes do i make to my harness in the car
