Originally posted by ericL@Sep 6 2005, 01:08 PM
no dude it's not hooked up...the iacv on the back of the intake manifold has no lines to go to..
[post=550186]Quoted post[/post]
Originally posted by ericL@Sep 7 2005, 10:09 PM
I got ahold of a helms and looked at how things are hooked up and I just want to check before i do this...
The coolant lines run from the engine to the throttle body out of the tb and to the IACV out of the IACV and to a T in the connecting coolant hose...now unless i'm missing something I can just run the line directly to the IACV (skipping the tb b/c there are no coolant inlets) and everything should work fine...
Also, just so I'm clear the unit on the bottom of a normal throttle body is the fast idle thermo valve right? Cuz whatever that is is not present on my TB...if this is not there would that cause fluctuation?
[post=551041]Quoted post[/post]
