either will work, but the obd2 ecu will require the conversion harness to connect to your obd1 car (assuming its an ej as your username implies).
It doesn't really matter much as the y8 and z8 engines are pretty close. the y8 has a better head and IM setup but the fueling is pretty close and you won't notice much difference at all if any.
