PreludeProject95
Someone please guide me on the right direction I am no mechanic but I did a motor swap 100% by myself when my whole family was against it an said it wasn't worth it an I can't do it, but I seen potential in this car an I just can't wait to be able to say fuck y'all I did it Bitches an plus Ive done so much to the car now with it being my first an only motor swap BY MYSELF tha car means summin to me now if ya know what mean...
Anyways here we go,
Aight I bought a 95 Honda prelude last june an I can't get this Bitch right I'm so damn frustrated with it it ain't even fucking funny... This what I got an what I've done I Bought it an it had a H22a1 in it with a whole in tha Block... ( Junk ) lol so I listened to this guy online ( who has now Abandoned me so I need help ) but I ordered I believe it is a chipped p28 with base maps i pulled the H22A1 SET it on tha ground Bought a
JDM H23A an set the 2 motors side by side I stripped the H23A to nothing but a head an block pretty much an I put everything external off the H22A1 an put it onto the H23A Because the wiring harness that was in the car already
( I don't know if it was the factory harness or the h22a1 harness also does anybody know what motor came factory in my 95 lude ) so I slapped tha H23a with all the external parts from the h22a1 in tha car it fired right up.. But it just ain't running right... The only thing from the H23A that I'm using is the head an block an maybe the plug wires I can not remember witch ones I used
OKAY so,,,.
Now in the beginning It was running so rich I put a milk jug behind the exaust pipe an no exaggeration it literally turned the son of a bitch black,,, sut black... Also I do not know what I did to make it stop but it is no longer running that rich an puttin out all that black smoke but it is now getting gas in the oil instead of black smoking... This right here has always been one of the main issues since the car ever started the car will be idleing an you know the three wire clip that plugs into the map sensor well when it is plugged up and the other end which is a vacuum line well as soon as I plug that vacuum line up to the throttle body the car idles a little higher smooths out kind of like it's running right and then just dies every single time or vice versa if the three wire clip is unplugged and the vacuum line is plugged up the car will idle as soon as I plug the three wire clip in the car idle is higher smooth out kind of like it's running right and dies so pretty much what I'm getting to my understanding I could be wrong please correct me if I am but as soon as that ECU gets an accurate or wrong reading of what's going on the car dies... Throwing no codes. An no I DO NOT have the Map sensor an the TPS Backwards
Things I Have Replaced:
1. Map sensor
2. TPS
3. I Believe I changed all senors to do with temp or coolant.
4. Intake air temp sensor but not a new one I pulled one off another car at a junkyard just because I was there and I seen it so I figured I'd grab it you know what I mean... LoL
5. Whole intake gasket kit.
6. Clutch, pressure plate, throw out bearing, clutch slave cylinder, Master cylinder aw be damn if I put a new motor in and not change the clutch I had no idea how good or bad the other clutch was so I didn't want to put it in and have to pull it 6 months from then to change the freaking clutch...
If I can think of anything els I will add it but does anybody know what could be wrong or no if I did something wrong was I supposed to do something else I also read online that the only things you're supposed to use from the H23A is the head, block, and throttle body...
Does anybody know if this is true because if it is true then that means I'm using the wrong throttle body and the wrong map sensor because my map sensor is located on the firewall the map sensor that came on the intake of the h23 is located on top of the throttle body if ANYBODY CAN PLEASE HELP ME IM REALLY GOING THREW IT OVER HERE PLEASE CONTACT ME OR SEND MESSAGE... if u wanna hollar at me on Facebook my is AJ Pettit. An my profile pic is of me and my niece sitting down so just shoot me a message on there or something if you want or on here I appreciate it guys talk to you soon hopefully you can help me figure this out I'm about to junk this bitch LOL joking
Anyways here we go,
OKAY so,,,.
1. Map sensor
2. TPS
