Square bolts?
Briansol
Admins
Admin
VIP
What are these called?
A couple of my window latches are lose and I don't have a square drive tool
Square recess bits / Robertson bits
I've mostly seen them used for decking
Should be able to get a set anywhere that sells bits, if you don't already have them in one of the multi bit sets that come with every tool / drill kit on the planet
There is a chance they are loose, because they need to be.
Depending on the fit and finish of your windows, and the cost vs benefit calculations of the builder, sometimes those window locks are a bit wonky.
