Go Back   HondaSwap Forums > Members' Corner > Auto Multi-Media
Andrew's engine swap (pics)
Old 09-24-2008, 08:28 PM   #2351
My name is Byron.
efhondakid's Avatar
Ride:  89' DX Hatch w/B16
Rep Power: 221 efhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
efhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
Originally Posted by Andrew View Post
Looks SICK!!!
I second that.
^ (dont listen)
There is a hidden message here.
"Motor swaps, turbo kit installs, diagnostics, minor repairs, minor fab and bodywork. Located in Akron-Canton area PM me for more details."
"In the dice game of life who gets the last roll?"
Old 09-25-2008, 07:05 AM   #2352
I trained Trogdor to pWn
mac_24_seven's Avatar
Ride:  94 GSR Sedan
Rep Power: 16 mac_24_seven has a spectacular aura aboutmac_24_seven has a spectacular aura aboutmac_24_seven has a spectacular aura about
Here's the link to the site I was tellin you abotu with freaking awesome prices on pipe. Best I've seen,
mac_24_seven is offline   Reply With Quote
Old 09-25-2008, 08:54 AM   #2353
Conan The Hondarian
wikedeye's Avatar
Ride:  1993 Honda Civic Dx Coupe
Rep Power: 28 wikedeye is a splendid one to beholdwikedeye is a splendid one to beholdwikedeye is a splendid one to beholdwikedeye is a splendid one to beholdwikedeye is a splendid one to beholdwikedeye is a splendid one to behold
Send a message via AIM to wikedeye
^^^that is a good site. it looks like they have everything needed to build your own exhaust and mani.
Originally Posted by 99sidude View Post
yes silicone lubricant worked great on my shaft. highly recommend.
XBL: Wikedeye
wikedeye is offline   Reply With Quote
Old 09-28-2008, 05:41 PM   #2354
Andrew's Avatar
Ride:  1991 CRX Si
Rep Power: 47 Andrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to behold
Send a message via AIM to Andrew
Update!
I'll let the pictures do all the work.
The pics of the dents in my hood is where I got a little over-zealous and beat the underside of it and it warped the top a little bit. Some of it came out, but it's still there. It's ok, though. I have that carbonfiber hood I've been thinking of repairing and using, or I can just do a little repair to this metal hood.. no biggy.
the only thing holding me back from starting it is oil.
I talked to my tuner and he said to just turn down the fuel pressure to like 15-20lbs and see if that helps it idle (with these big injectors). That way I can heat cycle it and check for leaks and such!
I'm sortof scheduled to get it tuned with him (if all goes well) next Saturday!
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 09-28-2008, 05:50 PM   #2355
Yeah
EF9_Hatch's Avatar
Rep Power: 57 EF9_Hatch has a reputation beyond repute
EF9_Hatch has a reputation beyond reputeEF9_Hatch has a reputation beyond reputeEF9_Hatch has a reputation beyond reputeEF9_Hatch has a reputation beyond repute
Send a message via AIM to EF9_Hatch myspace
Lookin good man. Glad to see that thing is coming together finally.
"It's not what you drive, but how you drive it."
XBL Gamertag= W0BBnIT <---- 0 is a Zero
EF9_Hatch is offline   Reply With Quote
Old 09-28-2008, 06:07 PM   #2356
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
Rep Power: 214 INJEN78 has a reputation beyond repute
INJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond repute
nice!!!that is exciting.
R.I.P BEN LEE2/24/08 we love and miss you
http://burnoutbox.activeboard.com/in...BID=127652&p=1
GOOD FAST CHEAP,
you can pick only two.
fast and cheap isn't good
good and cheap isn't fast
good and fast isn't cheap
Old 09-28-2008, 09:13 PM   #2357
Rep Power: 38 NissanNiNjA2nd is a name known to allNissanNiNjA2nd is a name known to allNissanNiNjA2nd is a name known to allNissanNiNjA2nd is a name known to allNissanNiNjA2nd is a name known to all
Dude.... what in the name of all afro-engineering is going on there....
quad band clamps......
NissanNiNjA2nd is offline   Reply With Quote
Old 09-29-2008, 07:45 AM   #2358
Ride:  94 GSR Sedan
Hey man, whatever it takes to get the job done! I've used MUSTARD several times in my mechanic career to figure out tolerances and whatnot Whatever it takes
Andrew, thats sweet man! When are you gonna crank it? Man, I sure hope the headgasket is ok
1994 Acura Integra GS-R Sedan
My MAIN DB8 project thread on Honda-Tech: Very detailed of EVERYTHING I've done to my car.
Contact me for ITR header skid plates: $40.00 shipped!!!
Old 09-29-2008, 08:30 AM   #2359
Andrew's Avatar
Ride:  1991 CRX Si
If guys run just 1 ok, I figure I'll run 2 to be "safe." None of my T-bolt's were small enough.
way ahead of you. I took this last night but didn't upload until this morning. This is the "suprise" i had for ya.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 09-29-2008, 09:28 AM   #2360
Reverend Awptickes
awptickes's Avatar
Ride:  1999 Civic EJ9, 2009 Fit GE8, 2006 Suzuki SV650s
Rep Power: 184 awptickes has a reputation beyond repute
awptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond repute
 FaceBook
I vote for the CF hood.
Also, make Terrance take that POS back and have them weld some beads onto the ends. Or else 10 band-clamps won't hold it on.
Also, Nice.
☻/ DIY/Howto HID Projector retrofit
awptickes is offline   Reply With Quote
Old 09-29-2008, 10:16 AM   #2361
Andrew's Avatar
Ride:  1991 CRX Si
I thought about it. the first time it comes off is when it'll be taken down to him
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 09-29-2008, 10:21 AM   #2362
Reverend Awptickes
awptickes's Avatar
 FaceBook
Do it now, then you won't have to worry about it. It might be a good idea to bead the charge tube from the turbo too.
You need another silicone coupler, that one that is too big will come right off, no matter how many clamps you've got on it.
Old 09-29-2008, 10:41 AM   #2363
Ride:  94 GSR Sedan
I'm hurt
I'm sure I'll be over it soo..... Yep, I'm ok now.
I wish I had thought about that when I had it down here. Dangit.
Old 09-29-2008, 10:50 AM   #2364
Andrew's Avatar
Ride:  1991 CRX Si
It's not that its too big it's just a little bit of an angle, making the bottom poke up a little.
It should run pretty good for now. we'll see what happens when i start boosting it.
Actually a little boost leak wouldn't hurt me right now. I'm not so sure what this thing is going to do with 10 lbs(WG) so if it only boosts to 5-8 I'm good with that. I'll fix it accordingly, but just to be 'safe'...
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 09-29-2008, 11:37 AM   #2365
Ride:  94 GSR Sedan
Once you get it going, you can drive it down here one day, after school and I can have it fixed.
Old 09-29-2008, 06:36 PM   #2366
Andrew's Avatar
Ride:  1991 CRX Si
Compression results in from today All are OK except for #1 for some reason.
Rich much?
#1 = Fail.
It's GOTTA be the headgasket.
I'm going to try and get my hands on a leak down checker tonight and do that sometime this week...
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 09-29-2008, 08:15 PM   #2367
haao13's Avatar
Ride:  boosted sir eg, suzuki gsx750f
Rep Power: 11 haao13 will become famous soon enoughhaao13 will become famous soon enough
howd the hg go already?
haao13 is offline   Reply With Quote
Old 09-29-2008, 08:23 PM   #2368
Andrew's Avatar
Ride:  1991 CRX Si
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 09-29-2008, 08:55 PM   #2369
Korax's Avatar
Ride:  1990 ED DX jdm D15B dual carb;x 1991 ED DX B16A OBD0
Rep Power: 21 Korax is a glorious beacon of lightKorax is a glorious beacon of lightKorax is a glorious beacon of lightKorax is a glorious beacon of lightKorax is a glorious beacon of light
Send a message via AIM to Korax myspace
^ (;_; )
Second: I like the paper towel below the top rad inlet. "Leak?" "fuck it, paper towel FTW!" (^.^ )/
PSN: Korax37
Korax is offline   Reply With Quote
Old 09-29-2008, 09:24 PM   #2370
Andrew's Avatar
Ride:  1991 CRX Si
Haha thats exactly what happened. I slipped that snap clamp back and clipped in a worm clamp too. so now it doesn't leak... that was thankfully the ONLY leak i had during the runup and heat cycle process! wow is that cool. thats never happened to me before; on any of my engine swaps! IDK what that means. Better mechanic or Better motors?
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 09-29-2008, 10:24 PM   #2371
SOHC on this!!
GlassHeadlights's Avatar
Rep Power: 66 GlassHeadlights has a brilliant future
The test looked a bit unbalanced anyway. How long has it been running? Did you warm it up before the test?
Originally Posted by A notable gynecologist
The best engine in the world is the vagina. It can be started with one finger, it is self-lubricating, it takes any size piston and it changes its own oil every four weeks. It is only a pity that the management system is so fucking temperamental.
GlassHeadlights is offline   Reply With Quote
Old 09-29-2008, 11:44 PM   #2372
Getcha Mind Right
Rep Power: 0 chrism1829 has a little shameless behaviour in the past
Send a message via AIM to chrism1829
lol
chrism1829 is offline   Reply With Quote
Old 09-29-2008, 11:51 PM   #2373
Korax's Avatar
Probably better mechanic. If you do it enough you're bound to get better. I haven't done anything much so I'm terrible. Sounds right to me, haha.
PSN: Korax37
Old 09-30-2008, 12:04 AM   #2374
SOHC on this!!
Originally Posted by chrism1829 View Post
lol
Shit, reread nvm.
Old 09-30-2008, 08:08 AM   #2375
Ride:  94 GSR Sedan
For the record, I tried to get Andrew to do a compression test THE DAY WE DRILLED THE HEADGASKET!!! Or at the bare minimum, shortly after.
My reason: So when (yes, not if, WHEN) you test it and its leaking, you can go ahead and get a new one in and ON your engine BEFORE you get your turbo stuff ready.
Now, your turbo is ready, but your engine is not. It does not make me happy in the pants. And I don't like not being happy in the pants.
Anyway, get that leakdown test done Wednesday mang! And, if I was in yoru position, I'd order a OEM headgasket and throw on your 5 lb or 7 lb wastegate and call it a day. Plenty of 11:1 CR motors out there with bewst. You know Max is gonna put a good, safe tune on there.. and thats the main thing to worry about. I mean, think about Tracy's 302: 15:1 compression ratio and he's spraying 150 shot of nitrous. I have no idea what that static CR (isn't that the right one?) goes to when he's spraying, but it's gotta be alot.
My .02
Engine swap: d15b7 to d16y7; transmission? oakley2002@cox.net HYBRID -> EG-EK / DC 7 10-28-2009 07:19 PM
Best Engine Swap For 95 Integra Ls Agt_Orange_GSR HYBRID -> EG-EK / DC 7 09-23-2008 04:16 PM
EE crx engine swap. DAZ81 HYBRID -> ED-EF / DA 6 11-25-2003 10:21 AM
81 Civic Engine Swap Help fjcisco13 HYBRID -> EG-EK / DC 3 04-23-2003 06:16 PM
