FüK-VTEC
Ride: 07 Nissan Frontier, 90 CRX Si, 06 ZX6R racebike, chopped-out 02 Yamaha V-Star
Yes, all 92 Civics were pre-wired for VTEC on the in-car harnesses. The wires are located in their respective pins on the strut tower plugs. If you're doing a VTEC swap, all you have to do is get a 92-95 Civic EX/Si harness or a 94-01 Integra GSR harness and plug it into the strut towers.
hey bud i am boing a d15b vtec jdm swap. i know the d16 harness will fit, but do i have to run it from the ecu out or just to the shock towers.
also can i use the stock harness and then just run the vtec wires to the pin outs i have a non vtec d15b |
#5 |
FüK-VTEC
You only have to plug it in at the strut towers. Yes, you could use your stock harness and tap into the strut tower plugs for VTEC, but it would look much cleaner and be a lot easier if you just get a VTEC harness and plug it in.
You can find a picture of the wires you'll need on your shock tower on FF-Squad.com, or you could just click here: http://www.ff-squad.com/tech/wiring/...ktowerplug.jpg Your in-car harness is wired for VTEC; your stock engine harness is not. If you use a USDM VTEC engine harness everything will work fine, with no soldering at all. The ONLY problem you MAY run into is with your O2 sensor; you'll have to use whatever O2 sensor that corresponds with your ECU. If you keep the JDM D15B VTEC ecu, you'll have to use a one-wire O2 sensor, and if you use a P28 (better idea in the long run, IMO) you'll need to use a 4wire O2 sensor. |
| ALL CIVIC PARTS MUST GO | ddubz712 | Parts: For Sale/Trade/Wanted | 12 | 11-10-2006 12:29 PM |
| fs: civic parts | phengnhou | Parts: For Sale/Trade/Wanted | 0 | 01-19-2006 10:16 AM |
| Anyone here? | 2000Si | Members' Lounge | 14 | 12-09-2003 11:55 AM |
| All This Reference Material, And No Cel Code Chart | Slo86GT | Members' Lounge | 5 | 06-13-2003 10:31 AM |
| Chassis Code | VSMB16A2 | General Tech and Maintenance | 10 | 01-22-2003 05:32 PM |
