nonvtec dizzy in z6
reckedracing
TTIWWOP
VIP
just looking to see if it will work for a test firing...
i will be getting the z6 dizzy, but want to give the motor a spin...
have an obd1 dx dizzy, actually 2 non-vtec dizzy's...
i've never done it, so i can't confirm, but word on the street is that it won't work. not sure why...
I have done it. you can do it. But you have to get the timing right and the bolts don't even match up . you have to hold the dizzy on and have someone start the car. I did it on my b7 mini-me to get it to start before i got my z6 dizzy.
yep you can do it. the previouse owner of my rex BROKE parts of the bracket,and then put a big washer on the top bolt to hold it on. How rice is that? anyway it will work.
I had my stock crx dist. on my vtec head and ran it that way for a year
you can also swap out the guts of the non vtec dist and put them into the vtec dist, so that way the bolts line up
[post=495579]Quoted post[/post]​
that the way to if you find a housing. I found my dizzy from a fellow HS member.
yup it can def be done but you have to hack off one of the dizzy holes and nigrig it with a washer. a freind of mine did it with a cx dizzy on a z6 bout 2 months ago and he hasnt had a prob with it yet
