nonvtec dizzy in z6
Discussion in 'ECU's, Electronics, and Tuning' started by reckedracing, Apr 25, 2005.
  1. reckedracing
    reckedracing TTIWWOP VIP
    NY
    just looking to see if it will work for a test firing...
    i will be getting the z6 dizzy, but want to give the motor a spin...
    have an obd1 dx dizzy, actually 2 non-vtec dizzy's...
  2. pissedoffsol
    i've never done it, so i can't confirm, but word on the street is that it won't work. not sure why...
  3. reckedracing
    NY
    i know it won't bolt up well... perhaps 2 bolts? maybe only 1...
    but i just want to fire the bitch up...
  4. 4DRonDUBS
    4DRonDUBS Senior Member
    I have done it. you can do it. But you have to get the timing right and the bolts don't even match up . you have to hold the dizzy on and have someone start the car. I did it on my b7 mini-me to get it to start before i got my z6 dizzy.
  5. Taco15
    Tallahassee Fl
    yep you can do it. the previouse owner of my rex BROKE parts of the bracket,and then put a big washer on the top bolt to hold it on. How rice is that? anyway it will work.
  6. ripperbone
    ripperbone angry bear
    Oklahoma
    I had my stock crx dist. on my vtec head and ran it that way for a year
    you can also swap out the guts of the non vtec dist and put them into the vtec dist, so that way the bolts line up
  7. Taco15
    Tallahassee Fl
    that the way to if you find a housing. I found my dizzy from a fellow HS member.
  8. PhyRe
    PhyRe Senior Member
    ct
    yup it can def be done but you have to hack off one of the dizzy holes and nigrig it with a washer. a freind of mine did it with a cx dizzy on a z6 bout 2 months ago and he hasnt had a prob with it yet
