Dyno chart for my new engine build
Old 09-16-2003, 08:22 PM   #1
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Rep Power: 288 Calesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud of
Hey guys, here are the dyno charts you've been waiting for... but first a little intro material. The engine build this time is a high 11 to low 12 point compression setup (not 100% sure what it really is). Bore is 85mm and stroke is 89mm. The sleeve is by Golden Eagle, and the rest of the block hardware (oil squirters, oil cooler, factory catch can, girdle) is standard GSR stuff. The pistons are strutted high wrist pin units by Endyn, and the rods are custom length units from Eagle. The head is 100% stock right now, except for a pair of Skunk2 cam gears that are set at zero. More on that later.
Dyno charts are 600x450, and are clickable for 800x600 images in a new window.
This first dyno chart shows the engine trimmed in on a Hondata S200 system. The blue lines are from a base map pulled from a previous customer's high compression B20/VTEC build. The red lines are my engine. The power peaks at around 7000rpm, which is lower than my previous B20/VTEC build. That's a good thing. The torque curve is higher and flatter as well, and falls off slower past the peak than the last build also.
This second chart shows what happens when you start playing with the cam timing. Just by changing a few degrees, you shift the entire power curve. We weren't showing any improvements over the entire rev range, but playing with the intake cam timing WAS able to give a 7hp increase in all revs below VTEC. At the same time, it killed power above VTEC. We were not able to get any favorable results with rough cam tuning, so timing was left at zero for both the intake and exhaust. The cam timing will get played with again when new camshafts go into the engine.
Just FYI, I think the intake timing was retarded a 2-3 degrees between the two power curves shown above.
We made one more run later that night with everything set back to normal, and the output was:
185hp / 152lbft at the wheels
Those are the numbers I'm sticking to. Enjoy.
Old 09-16-2003, 08:32 PM   #2
Calesta's Avatar
Ride:  2003 S2000
For comparison's sake, I took my old dyno chart from the old engine build (2 years ago) and stretched it out until the scale roughly matched the new charts:
One more... I popped open Paint Shop Pro and started fiddling around...
The green lines are from my old B20/VTEC graph. I thought this was pretty interesting... you can clearly see how my new GSR engine build is superior to the old B20/VTEC engine setup from the torque and power curves. The low end is much stronger, and everything from VTEC to 7000rpm looks much better. The really interesting thing here is how both the new and old engine build's power and torque curves are virtually identical beyond 7000rpm.
This leads me to believe that the B16 head just can't flow past 185whp in stock form under a naturally aspirated engine build. I didn't make my 200whp target, but I'm pretty sure I'll get close to my ultimate goal once I start playing with the head. 250whp is the target- we'll see if I can nail it.
Old 09-16-2003, 08:48 PM   #3
Member of the 20 nut club
E_SolSi's Avatar
Rep Power: 527 E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
looks good .... nice Tq
МОΛΏΝ ΛΑΒΈ
Old 09-16-2003, 08:50 PM   #4
Rep Power: 17 b16ahatch is off the scale
nice numbers. what motor is it and are you n/a?
94 cx hatchback
mods
exterior- si wheels rapped in falken azenis, carbon fiber hood, carbon fiber wing, projector head lights, si paint job and m3 mirrors
under the hood - b16 sir2 swap, clucth masters stage 3 clutch,act lightend flywheel, eagle rods, arias pistons, darton sleeves, rc 370cc injectors, msd plug wires,jackson racing fuel pump, apexi avcr and vafc, thrermal 3 inch turbo exhaust, 3 inch down pipe, auto tecknic fuel rail, b and m fuel pressure regulator,aem cam gears, turbonetics t3/t4e turbo, spearco fron mount intercooler, greedy type s b.o.v,
future mods- crane 2 step rev limiter igniton system, pnp head, crower valve train, and a apexi power fc.
b16ahatch is offline   Reply With Quote
Old 09-16-2003, 08:52 PM   #5
E_SolSi's Avatar
dont just look at the pictures
READ THE DAMN POST!!!!!!!!!!
his entire setup is completly spelled out right there in front of you
МОΛΏΝ ΛΑΒΈ
Old 09-16-2003, 08:55 PM   #6
whoops... i feel stupid sorry for the dumb question
94 cx hatchback
mods
Old 09-16-2003, 08:57 PM   #7
Rep Power: 26 SleEPeR_CRX is off the scale
nice mang, cant wait to see what it will pull with some cams in there, and some nice 1/4 mile times.
Sleepers Are the Only way to Go.
1990 CRX Si
B18a(92) CAI/E, Gutted, ACT clutch/pressure plate/13lb flywheel, Crower 403 Cams, Titanium Valve springs & Retainers, Blockguard, Head Milled 20 thou, 9.8:1 Compression, AEM cam gears.
1/4 = 14.73
60' = 2.48
trap = 95.03mph
Soon to get: Header, Slicks
Future 13 second all motor LS!
SleEPeR_CRX is offline   Reply With Quote
Old 09-16-2003, 09:00 PM   #8
Calesta's Avatar
Ride:  2003 S2000
Thanks guys! Take a look at the last chart... it's the real eye-opener. The new engine build is on a Hondata setup, while the old B20 was on a VAFC. Both were tuned to maximum power across the rev range while maintaining as constant an a/f ratio as possible.
Old 09-16-2003, 11:11 PM   #9
B16
B16's Avatar
damn, that thing is torquey, my B16 is jealous
good numbers meng
that is on stock cams correct? if so, i'd like to see they dyno after headwork, damn!!
2004 BMW 325i
2000 Mercedes Benz ML 430
Old 09-17-2003, 04:30 AM   #10
Calesta's Avatar
Ride:  2003 S2000
Yup, stock cams, stock cam timing, stock unmodified head casting, stock valvetrain, stock intake manifold... there's a lot left in the engine.
Old 09-17-2003, 10:58 AM   #11
Rep Power: 29 Frankie P. is off the scale
Send a message via Yahoo to Frankie P.
Also, if I may add Calesta, is his engine is runs extremely smooth up to redline. No jerks or power stall, if that made any sense, it also doen't show how sweet his handles are, best handling I have ever ridden in, better than my buddies 2001 Cobra. Very sweet ride.
Frankie P. is offline   Reply With Quote
Old 09-17-2003, 11:44 AM   #12
Rep Power: 16 gocivicls is off the scale
Send a message via Yahoo to gocivicls
Must be nice! Awesome build up, keep us informed on the charts after cams/headwork, etc.
<span style=\'color:red\'>14.2:1 CR LS with 405A's and working out the bugs</span>
<u>Fastest 60ft</u>
1.78
<u>Best ET on 1/8th</u>
8.42
<u>Fastest MPH</u>
82.23 mph
All Motor LS (B18B) <span style=\'color:green\'>Hasn't been tuned yet!</span>
gocivicls is offline   Reply With Quote
Old 09-17-2003, 12:16 PM   #13
88 C1V1C 53D4N DR1V3R
saturn_boy96's Avatar
Ride:  2006 Suzuki Aerio
Rep Power: 31 saturn_boy96 will become famous soon enough
Send a message via AIM to saturn_boy96 Send a message via MSN to saturn_boy96 myspace
<----------Jealous of having more than 150ft/lbs of torque...
saturn_boy96 is offline   Reply With Quote
Old 09-17-2003, 12:45 PM   #14
sohcslammer's Avatar
Rep Power: 35 sohcslammer is an unknown quantity at this point
Nice graphs cal, do you have any thoughts on what cams you are leaning to? Toda spec Cs? Keep us updated!
Latest project -
1 fucking fast 99 SI
sohcslammer is offline   Reply With Quote
Old 09-17-2003, 01:06 PM   #15
Calesta's Avatar
Ride:  2003 S2000
Thanks Frankie!
Cams- I don't know yet. I'm doing as much reading as I can. Skunk2 Stage2 and the Jun Type3 come pretty highly recommended from Intercrew, but Phillip builds cars mostly for straight line performance. I would like to get the same high end output as the Skunk2 and Jun cams so I can come as close as possible to hitting my 250whp goal, but I want more midrange too. I'm thinking about the Toda Spec Cs, but we'll see. For the price that Toda wants, I might get some custom Skunk2s or something, ground close to Todas specs.
Old 09-17-2003, 05:07 PM   #16
DarkHand's Avatar
Rep Power: 175 DarkHand has a reputation beyond repute
DarkHand has a reputation beyond reputeDarkHand has a reputation beyond reputeDarkHand has a reputation beyond reputeDarkHand has a reputation beyond reputeDarkHand has a reputation beyond reputeDarkHand has a reputation beyond repute
Awsome Calesta.
I've finally started saving funds for my swap, and the question on my mind is price. If you don't mind me asking, how much have you paid so far?
It's back! Keep up on the progress of my cars!
http://civicminded.wordpress.com/
Originally Posted by Celerity
They say you only use 2% of your brain. I wonder what we do with the other 94%.
Originally Posted by TurboMirage & Calesta
"Life is like a bag of Skittles... you have to eat all the colors"
DarkHand is offline   Reply With Quote
Old 09-17-2003, 05:55 PM   #17
Calesta's Avatar
Ride:  2003 S2000
Hmm... that's difficult to say. I've spent so much in so many different places that I really don't know how much is in this engine anymore. My first swap was $6000 installed, plus a few options- you could probably come up with something similar to my build for not much more.
Old 09-17-2003, 06:00 PM   #18
GNU/Linux Evangelist
lsvtec's Avatar
Ride:  The Cheapest Road Bicycle I could get
Rep Power: 69 lsvtec is on a distinguished road
Those are some really impressive numbers, especially with a stock head and cams. I can't wait to see the numbers you start putting out with a modified head.
v3sw7+9Chw6ln3pr7Ock4ma9w3TXm3l7GDF i7Ce6+8t4MNb8Oen6g6RAOa26s5MRp6 hackerkey.com
lsvtec is offline   Reply With Quote
Old 09-17-2003, 06:14 PM   #19
Calesta's Avatar
Ride:  2003 S2000
Yah... me too! Must get money first.
Old 09-17-2003, 06:35 PM   #20
I say if you can swing it, go with the Toda C. I am kinda biased towards Toda, mainly because of the awesome performance on the RSX-S. They might be expensive, but they are very high quality, but hey it's your build. Keep me informed Mike, not just by words, if you know what I mean.
Old 09-17-2003, 06:50 PM   #21
Calesta's Avatar
Ride:  2003 S2000
I'll keep you covered man- I should be in Austin for at least a few more years.
Old 09-17-2003, 09:04 PM   #22
Rep Power: 17 h82w8 is off the scale
that 6000 ballpark est. does that Include the 1000 dollar tiens? :P
1990 white crx dx immaculate shell... waiting
1995 black del sol VTEC,jdm B16A, black 15&quot; rota slips, BFG g-force ta kdw's, kyb agx's, eibach pro-kit, tanabe strut bars, tanabe hyper medallion, dc header
in 1962 honda launched their famous ad campaign:
&quot;you always meet the nicest people on hondas&quot;
...chirp
<span style=\"color:#3333FF\">WTB</span> gsr head , ls block, or b20 block.
h82w8 is offline   Reply With Quote
Old 09-17-2003, 09:22 PM   #23
Calesta's Avatar
Ride:  2003 S2000
No way. I said "swap", not the whole car build. That will cost you a LOT more.
Old 09-18-2003, 12:24 AM   #24
Very Very nice starting dyno with that build. Very good base line man.
This is all with the top still stock, timing stock, etc...very impressive.
good job man.
13.3@103 MT's &amp; Gutted
-Project 5 - Motor A (???)
Old 09-18-2003, 02:24 AM   #25
Calesta's Avatar
Ride:  2003 S2000
Thanks Milan. I was really pleased with the 150ftlb too. Now if I can just keep that 150ftlb flat all the way to 9000rpm, that would get me 257whp. Considering that a set of good cams alone would increase my torque band quite a bit, I think my goal may just be attainable... we shall see.
My car is done, engine build a success. Dyno here Import Builders Engine Building 23 06-25-2004 01:08 AM
How to build a panda engine Kolumbo69 Engine Building 6 01-04-2004 07:43 PM
Build Engine Or Swap? 98 4dr civic Engine Building 6 06-05-2003 10:33 PM
My Engine Swap Continues rsaeini HYBRID -> EG-EK / DC 23 03-22-2003 03:22 PM
D16 Engine Build pianoman Parts: For Sale/Trade/Wanted 1 03-17-2003 12:41 AM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
