VTEC killer cams,
Closed Thread
Old 02-14-2004, 02:56 AM   #1
Rep Power: 17 Sergey P.A. is off the scale
Send a message via Yahoo to Sergey P.A.
Unhappy
ok I went to a performance shop today, and they had some new and weird shit, I don't know if it's new but its funking owesome,
1st one, I saw some TODA cams and I asked the guys what kind of cams are thise and he said its a VTEC killer cams, I was like yeah right cuz the cams had only the side lobes,no middle one, but the lobes were oversized, he said that this are cams for drag racing strait, not for street use, and he also said that the vtec is on all the time with this shit, so if you kknow what it is can somebody expayin it to me,
2nd thing is I say a IM which basically had a throtle body for each cilinder, that's not new to me, if somebody know's what I am talking about here explain pleaze
<_<
I am a simple man with a simple mind</div><table border=\'0\' align=\'center\' width=\'95%\' cellpadding=\'3\' cellspacing=\'1\'><tr><td>QUOTE </td></tr><tr><td id=\'QUOTE\'></td></tr></table><div class=\'signature\'>
Sergey P.A. is offline
Old 02-14-2004, 03:41 AM   #2
Rep Power: 18 H22AdelSol is off the scale
You mean individual throttle bodies?
<span style=\'color:red\'><span style=\'font-family:Geneva\'>94 JDM H22A|5spd-LSD|GSR Spec Brembo Cross Drilled and Slotted Rotors| GSR Front Calipers| SS Lines|Tokico Illumina Struts| Skunk2 Coilovers| AEM Fuel Rail| ACT Stage 3 Clutch /w Xtreme Pressure Plate| 8lb Kaiten Kairu Super Flywheel</span></span>
H22AdelSol is offline
Old 02-14-2004, 03:46 AM   #3
yeah, and how this thing works, it doesnt have a intake, or this thing is for DragSters only,
Old 02-14-2004, 05:08 AM   #4
Member of the 20 nut club
E_SolSi's Avatar
Rep Power: 546 E_SolSi has a reputation beyond repute
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
yes you can run an air box with ITBs
generally you need to run a full standalone for ITBs (as far as i know hondata can not deal with them)
VTEC killer cams are pretty much exactly what he said
it would be equivalent to running an LS head with VERY agressive cams
no VTEC engagement... basicly high lobes 100% of the time
МОΛΏΝ ΛΑΒΈ
E_SolSi is online now
Old 02-14-2004, 06:26 AM   #5
Rep Power: 20 97CTR is off the scale
VTEC "killer" cams= no vtec, it got killed
97 ex coupe
Wire tuck in progress....
97CTR is offline
Old 02-14-2004, 12:08 PM   #6
FüK-VTEC
civicious's Avatar
Ride:  07 Nissan Frontier, 90 CRX Si, 06 ZX6R racebike, chopped-out 02 Yamaha V-Star
Rep Power: 189 civicious has a reputation beyond reputecivicious has a reputation beyond repute
civicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond repute
Send a message via AIM to civicious myspace
on ITB's, how would you wire that up? like where would you put map/tps/iat sensors and your vacuum lines and such?
CMRA #265
http://www.myspace.com/civicious
AIM: greyfades
civicious is offline
Old 02-15-2004, 03:05 AM   #7
man the ITB's are crazy, kinda expensive though,
Old 02-15-2004, 03:08 AM   #8
...and you don't kill the VTEC, you have it, but it's allways on, that's not like for street use when you use it only when you need it, that's for Dragsters Only,
Old 02-16-2004, 07:17 AM   #9
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
depends on the model.
most, you have to vacuum port in. standalone time.
pissedoffsol is offline
Old 02-16-2004, 07:50 AM   #10
wrong, you don't have vtec anymore, you have only one cam lobe, with no lobe change over that means no vtec lobe. if you want to call it constant vtec go ahead.
97 ex coupe
97CTR is offline
Old 02-16-2004, 04:09 PM   #11
E_SolSi's Avatar
look.... these are explained right on todas fucking website
just go there and read
http://www.todaracing.com/products/honda_b...tec_killer.html
МОΛΏΝ ΛΑΒΈ
Old 02-16-2004, 04:19 PM   #12
CRX_B16B's Avatar
Rep Power: 16 CRX_B16B is off the scale
Originally posted by 97CTR+Feb 16 2004, 07:50 AM--><div class='quotetop'>QUOTE(97CTR @ Feb 16 2004, 07:50 AM)</div><div class='quotemain'> <!--QuoteBegin-Sergey P.A.@Feb 15 2004, 03:08 AM
wrong, you don't have vtec anymore, you have only one cam lobe, with no lobe change over that means no vtec lobe. if you want to call it constant vtec go ahead. [/b][/quote]
you'll have two cam lobes with the TODA vtec killer (im pretty sure) and only one with the crane cams vtec killer which requires special rockers so you never have the vtec function with these. just really big cams.
1990 civic STD Mini-Me swap and T3 HMT setup....
CRX_B16B is offline
Old 02-16-2004, 04:56 PM   #13
exactly what E said, and go visit his link
have a nice day
13.3@103 MT's &amp; Gutted
-Project 5 - Motor A (???)
JDMilan is offline
Old 02-17-2004, 02:52 AM   #14
RETIRED
no, you won't.
Old 10-31-2006, 11:34 PM   #15
Rep Power: 0 kennyrocks is on a distinguished road
Default duh...
<quote>1. The Primary and secondary lobes are designed to be the same size.</quote>
off toda's web site
so yeah 2 lobes
kennyrocks is offline
Old 11-01-2006, 12:11 AM   #16
Führer Mod
eg6sir's Avatar
Ride:  Le Car
Rep Power: 383 eg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
eg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
Send a message via AIM to eg6sir Send a message via Yahoo to eg6sir myspace  FaceBook
wow noob.. 2 1/2 yrs old..
DO NOT PM ME WITH TECH QUESTIONS!
XGT: cEElint
Originally Posted by 93civicracer View Post
my dad owned a Chevelle with a hemi that he claimed made 600hp.
eg6sir is online now
Closed Thread
B Series Cam Guide JDMilan Reference Materials 35 04-13-2007 09:26 PM
vtec killer cams cycloneb18c3 Engine Building 5 04-13-2004 04:11 AM
Vtec Killing Cams, What Is The Point? MaaseyRacer General Tech and Maintenance 3 03-24-2003 11:33 PM
