H22 swap problem please help
Old 08-25-2006, 12:36 AM   #1
SmokinH22CL's Avatar
Ride:  98 Acura CL
Rep Power: 7 SmokinH22CL is on a distinguished road
Default H22 swap problem please help
new here.. new here check this out
sup yall, im kinda a noob on engines and swaps so bare with me.. anyways just bought a 98 acura cl h22 swap and it has some problems.. the car runs smooth but the problems are - redlines at 4000rpm most of the time! and sometimes out of nowhere the vtec works then redlines at the cl ecu setting.. i know the car is obd2 and the engine is obd1, its runnin on the cl ecu and im pretty sure that i need the p13 ecu and obd2-obd1 wiring harness.. some people say that the p13 will not work because my key has a chip in it.. i dont know!.. anyways the engine light is blinking and found out the codes.. 22 - vtec system malfuction, 23 - ks circuit malfunction, 65 - secondary h02 heater circuit fault (sensor 2), and 71,72,73,74 - misfire or random misfire on all cyl. is that becuase the h22 is running on the cl ecu or what? what all do i need to get the car running right! thanks
oh yeah i also took it up to a local shop and they were suprised on how the car is even running! they said they dont even know what to do with it.. i was like what the heck? im not going back to that shop again!
SmokinH22CL is offline   Reply With Quote
Old 08-25-2006, 01:05 AM   #2
Ride:  98 Acura CL
does anybody know what will solve this problem?
Old 08-25-2006, 02:01 AM   #3
HS Troll...And Mod
reikoshea's Avatar
Ride:  2001 Honda S2000
myspace
the CL ecu is causing all of your problems. changing over to obd1 should fix your problem because your computer is not looking for an ignition code.
Anime Informant
reikoshea is offline   Reply With Quote
Old 08-25-2006, 02:53 AM   #4
Ride:  98 Acura CL
alright cool, so the p13 ecu and obd2-obd1 jumper harness is all i need????
Old 08-25-2006, 04:45 AM   #5
Ride:  98 Acura CL
just want to make sure that this is all i need.. everything is plug and play? no cutting wires?
Old 08-25-2006, 07:47 AM   #6
HS Troll...And Mod
reikoshea's Avatar
myspace
this is a very unorthodox swap, but im going to say yes, because the people that swap the h22a into the 97-01 preludes only need the jumper harness.
Anime Informant
Old 08-25-2006, 11:12 PM   #7
Ride:  98 Acura CL
im thinkin about goin either p72 or p28, and goin with hondata s100 system.. dont really know much about it so will i have to send the ecu to get it tuned for the h22?? im not even sure which jumper harness i need.. obd2a-obd1 or obd2b-odb1...... anybody know?
Old 08-26-2006, 03:55 AM   #8
HS Troll...And Mod
reikoshea's Avatar
myspace
what year is your car?
Anime Informant
Old 08-26-2006, 04:38 AM   #9
Ride:  98 Acura CL
1998..
Old 08-26-2006, 05:46 PM   #10
HS Troll...And Mod
reikoshea's Avatar
myspace
for civics, that is obd2a
Anime Informant
Old 08-26-2006, 06:12 PM   #11
Ride:  98 Acura CL
well most people dont know that the first gen acura cl is pretty much the same as the 94-97 accord.. whats the difference between obd2a and obd2b? could i tell by looking at my ecu? like the plugs or something?
Old 08-28-2006, 08:47 PM   #12
Ride:  98 Acura CL
i found out which one it is.. my ecu uses the left 3 plugs so that means i have obd2b.
H22AdelSol's H22A swap guide. H22AdelSol HYBRID -> BA-BB /CA-CD 14 08-04-2008 09:53 PM
B18c5 Eg Swap Problem. Need Help Please !!! newEGtypeR HYBRID -> EG-EK / DC 3 08-08-2006 05:57 AM
All Swap Info for EF Riceras HYBRID -> ED-EF / DA 2 02-07-2005 03:20 PM
H22 swap in to a 96 H/B civ96 HYBRID -> EG-EK / DC 16 04-12-2004 10:30 PM
h22 swap wiring problem tlmg21700 ECU's, Electronics, and Tuning 5 12-18-2003 11:02 PM
