Individual Throttle Bodies
Old 03-06-2004, 12:46 AM   #1
Rep Power: 14 b16coupe is off the scale
Send a message via AIM to b16coupe
I have been looking for a while and can't find much on this. I was wondering what kind of power gains could be made with an ITB setup on a stock b16. If it is useless to use them on stock motors then please tell me what modifications would have to be done to the motor for it to make a difference.
I've read on like two sites that it will have a 10-20 hp increase. Is this false?
93 civic ex
b16a sirII
Y21 w/lsd
205/40/16 nitto neo gens (better than nt450's)
Exedy Clutch
ctr pistons
no more turbo...stupid ring lands
b16coupe is offline   Reply With Quote
Old 03-06-2004, 12:56 AM   #2
Rep Power: 59 hcivic.com is on a distinguished road
itb should be near the end of you list then run 2000 or so bucks what do you have for mods and what do you wnat out of the car
hcivic.com is offline   Reply With Quote
Old 03-06-2004, 01:17 AM   #3
dohch22a4's Avatar
Rep Power: 31 dohch22a4 is off the scale
Send a message via AIM to dohch22a4
Before you invest in ITB's, you are gonna want some big, nasty cams like Toda B's or Jun 3's, a nice PnP, and a nice header like SMSP or JG. Otherwise, it's just not worth the money.
"Conventional wisdom would have one believe that it is insane to resist this, the mightiest of empires... but what history really shows is that today's empire is tomorrow's ashes, that nothing lasts forever, and that to not resist is to acquiesce in your own oppression. The greatest form of sanity that anyone can exercise is to resist that force that is trying to repress, oppress and fight the human spirit."
-Mumia Abu-Jamal
dohch22a4 is offline   Reply With Quote
Old 03-06-2004, 01:47 AM   #4
I'm not really looking at the money issue right now. Just wondering what kind of power gains (if any) could be had by itb on a stock motor or a mildly modded one.(like with itr cams and 2 layer headgasket)
93 civic ex
b16a sirII
Y21 w/lsd
Exedy Clutch
ctr pistons
Old 03-06-2004, 01:55 AM   #5
dohch22a4's Avatar
Sure, you'll see some power gains, but again, probably not enough to justify spending $2000. You may see a few more peak hp over an ITR intake manny, but is that really worth an extra 1700 dollars? I don't think so.
-Mumia Abu-Jamal
Old 03-06-2004, 02:47 AM   #6
Member of the 20 nut club
E_SolSi's Avatar
Rep Power: 430 E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
ITBs will not do dick for you on a stock or near stock engine
МОΛΏΝ ΛΑΒΈ
E_SolSi is online now   Reply With Quote
Old 03-06-2004, 06:40 AM   #7
Rep Power: 0 dr_latino999 is off the scale
You will want to be able to look at the engine and go "Damn, nothing else to do..." which in itself is a lie and then you will see max gain from ITBs. But it would be nice to see how much power people who have said that have seen.
DESPERATELY in need of 89-91 SI L3 Transmission.
Buy my stuff - <a href=\'http://honda-tech.com/zerothread?id=1108291\' target=\'_blank\'>FS/WTB Thread</a>
dr_latino999 is offline   Reply With Quote
Old 03-06-2004, 09:06 AM   #8
Rep Power: 20 lude68 is off the scale
You dick shits! make some homemade itbs(or give me a holler )...heres a clip of a b16 and his setup
the car in the vid, is a stock bottom end b16, with a port/polish head, ITR cams, DC 4/2/1 header...and home made ITBs. this car required little tuning. We bolted these on, and drove the car to the dyno 30 miles away. once you get the tps right, you are good.
http://www.styleandspeed.com/2...e.mpg
here is the dyno chart.....
You will notice that there is a 28whp gain. There is no way way I can attribute a full 28whp gain to ITBs. In between the 134whp and 162whp pulls, we also added a DC 4/2/1 header and removed the cat. (there was about a 1 month difference between dynos on this car) I give the header and the cat about 12whp gain, and I attribute the rest to the ITBs. You can see that there is a big difference at the very low and very high rpms......
...hopefully tomorrow I will have another chart to post where the only difference is the addition of ITBs and nothing else.
93 Civic hatch w/94 GSR ...ITB's BABY!!!! <span style=\'color:blue\'>FOR SALE</span>
JDM ITR pistons
ITR flywheel
Proclutch STG3 six puck clutch
Homemade ITBs
DC 4-1 header (holding back a lot of power)
<span style=\'color:red\'>HIT ME UP IF YOU WANT SOME HOMEMADE ITB's!!!</span>
lude68 is offline   Reply With Quote
Old 03-06-2004, 09:09 AM   #9
Rep Power: 18 hybridsol is off the scale
Send a message via AIM to hybridsol
up the compression to like 12:1, aggressive cams, crazy head work, full standalone system, lots of dyno time. anything less than that is a really expensive way to go slow
<u>My JDM, H22, ITR, Turbo'd Integra</u> <a href=\'http://honda-tech.com/zerothread?id=831210\' target=\'_blank\'>click here!</a>
<u>project RHD sleeper hatch</u> <a href=\'http://honda-tech.com/zerothread?id=1190974\' target=\'_blank\'>click here!</a>
hybridsol is offline   Reply With Quote
Old 03-06-2004, 10:52 AM   #10
Ride:  93 del Sol Gas sipper
Rep Power: 100 asmallsol is a jewel in the roughasmallsol is a jewel in the roughasmallsol is a jewel in the rough
that basicly sums it up. If your going all motor, this would be your last possible mod. You need loppy cams, lots of compression, huge PnP job, springs, valves, retainors, more headwork, crazy expensive header, and shit load of tuning.
Collin
Material Science and Engineering
Michigan Technological University
Old 03-06-2004, 11:16 AM   #11
Rep Power: 80 JDMilan is off the scale
good gains can be made with the ITB's but like most mentioned it would run toward the finale of your tuning and motor build.
ericks racing doesnt use one, why should I
13.3@103 MT's &amp; Gutted
-Project 5 - Motor A (???)
Old 03-06-2004, 03:50 PM   #12
Rep Power: 22 cycloneb18c3 is off the scale
Send a message via AIM to cycloneb18c3
there was a whole big write up in HCI december 03 issue. and they got a lot out of their ITB system. They actually blocked off the injector holes and custom made a mount and ran the fuel injectors into the end of the TB's. just changing the injector location they got a 14hp gain. we called TWM and they said you would need about 2600 to get it all working correctly.
whoever said nothing is impossible, never tried slamming a revolving door
cycloneb18c3 is offline   Reply With Quote
Forum Jump
throttle bodies wisemansoji General Tech and Maintenance 2 07-05-2004 11:32 PM
quad throttle bodies nightrider Engine Building 15 07-10-2003 11:08 AM
Individual Throttle Bodies K2e2vin Engine Building 19 05-11-2003 08:23 PM
Throttle Bodies Canadian_GSR Engine Building 4 04-24-2003 10:47 PM
Individual Throttle Body bluepearlintegragsr HYBRID -> EG-EK / DC 15 02-09-2003 07:21 PM
SEO by vBSEO 3.2.0
 | a SkeyMedia Network site
