95 integra 5speed, 92-93 b18b integra engine just swapped in. dont ask why i put a da motor in. cheaper and immediately available.
anyhow, i changed thermostat. still over heating. i bled the coolant system with heater on hot but it wasnt full blast for the whole time. there werent many if any air bubbles comming out of the rad.
i did use the bleeder screw, tightened when steady stream came out, filled rad up, turned on car till the fan cycled on and off twice, put the rad cap back on
my fan does come on, but it doesnt seem like its comming on when driving
so heres my symptoms:
- car at idle does not over heat
- driving for no more than 5 minutes the car will over heat
- little heat blowing out of heater
- when i down shift and accelerate and get moving faster the temp will go down but only so far, and eventually will work its way back up once im cruising at a low rpm and steady speed
please dont say its my water pump
