yea the turbo works! Everything above is new unless posted otherwise!
ALSO EVERYONE WHO IS WAITING ON PICTURES I DO NOT HAVE A WORKING CAMERA AT THE MOMENT BUT AS SOON AS I GET ONE I WILL POST PICTURES!
$2600 SHIPPED for all this.. Its all BRAND NEW inless stated otherwise!!! Got a little over $2800 into it all.. Im willing to take a hit to just get rid of it all and make some of my money back..
Cometic Exhaust Gasket............................$ 28
Allen Head Valve Cover Bolt kit.................$16
Oil Catch Can Kit ................................... .....$20
Fuel Pressure Gauge kit ............................$25
Rear Main and Timing Cover Seal ...........$27
Hondata C5 Intake Mani Gasket ..............$50
Turbo Oil Iine Kit(54" Line) .......................$53
10.3mm OBX Plug Wires.......................... $58
Darton 81.5mm Sleeves ............................$350
9lb F1 Flywheel ................................... ........$100
AEM Tru Time Cam Gears ........................$70 (used 200 miles)
ARP Head Studs ................................... .....$120
KMS Block Guard ................................... ....$93
ARP Flywheel Bolts ................................... .$55
GSR Timing Belt ................................... ......$55
Clevite Assembly lube ................................$10
ACL Race Bearings LS .............................$100
AEM Fuel Pressure Regulator ..................$80 (used 200miles)
Rear Main Seal ................................... ........$17
LS Eagle H Beams ................................... .$265
Light Weight Crank Pulley ........................$30
Low Temp Thermostat ...............................$20
KMS Cam Seal ................................... ........$12
GSR Cams ................................... ...............$113 (used)
T3 Turbo Gasket ................................... ......$8
EG Amber Corner Lights .............................$20
Turbo Oil Restrictor ................................... ..$19
F1 Stage 3 clutch kit ................................... $146
T3/T4 Turbo (Ebay)......................... ..............$145
Waste gate dump tube kit ..........................$48
Lower Motor Mounts ................................... $60
Polyurthane Motor Mounts .........................$185
LS Crank ................................... ..................$100 (used 80k)
SRP Pistons 9:1 81.5mm ......................$185 (used 100 miles)
is it the mishimoto monster or whatever? the fat one? i dunno if it will fit in my 89 ef. shit, it should but i dunno i gotta take a peek under the hood in a minute
the intake is the monster carbon fiber one and yea it should fit an ef!
As for the intake manifold man it no longer has the butterflies but it is intact eith the throttle body still!
