i need so help with my honda del sol
Ian Martin
ok i have a 1995 del sol with the d16z6 and im tryng to make it a 5 speed and idk what i need to do that will some one give me a list of stuff i will need a what tranny that will mach
He actually posted asking if he can make it a 5-spd, unlike some of the other members I have had 4spd that's why I asked that. I'm backin' down now, let's get back to the topic.
Haha, easy on me I'm just a noob. Atleast I now know that there was never a 4-spd manual Del Sol. Good lessons to be learned on here:).
I think your conversion is the least of your problems. Grammar might be something you should look in to. Proper sentence structure makes it easier for someone to understand what they need to type in their google search bar.
Man, did this site go to shit or what...?
Instead of bashing the guy that can't read whether the Del Sol was automatic or manual already, or bashing the other guy that apparently has grammer problems...., how about someone make a list of parts this guy needs for his conversion...?
For example:
- d-series manual transmission
- shift linkage w/ shifter
- clutch line
- clutch master cylinder and reservior
- pedal assembly
- ECU from manual trans car with D16Z6 motor or similiar
- Honda MTF
- Clutch and Flywheel w/ bolts
- Manual passenger side trans mount
That's all I could think of right now. I hope this helps a little.
For example:
- clutch line
- pedal assembly
- Honda MTF
Thanks, I don't know what their problem is but your right we should be trying to help rather than bashing eachother!!.
