OBD0 or OBD1??????
EWstryder
i have a DOHC ZC in my 86 CRX SI...heres the question...how can i tell if its OBD0 or OBD1? and where can i find a performance chip for it? the ecu has the numbers 37820-pg7-6640-401-116706
index.cfm
Why don't people do some research before posting...
every car before '92 is obd0, between 92-95 is obd1, and 96+ is obd2.
Also, dont quote me, but the pg7 ecu is a obd0 ecu.
it is OBD0, however, the 86-87 Integra PG7 ECU (which you have) can't be chipped easily, if at all - you could convert the car to run the 88-89 Integra electronic ignition timing advance distributor and then use a chipped PM6 or PM7 ECU
