hatchedlsvtec
Large Member
I have seen many threads about this problem but I have not really found an answer for my situation. I have a 91 civic hatch with jdm obd0 b16a. I am using one single wire o2 sensor at the main collector on aftermarket headers. No cel. When driving at a steady speed below 3k rpm, when I try to accelerate just a little bit, it slows as if I'm letting off the throttle until I push the pedal more than half way down, then it kicks, and runs perfect. No problems at heavy throttle and idle. Do I need to get and wire in another o2 sensor to fix this? If so, does it wire into pin C8? btw I am using these NEW parts:
-distributor.
-spark plugs
-1 single wire o2 sensor
-spark plug wires
-distributor.
-spark plugs
-spark plug wires
