i have a 94 integra, with-
b18b1 block
b18 head(crane cams stage 2,titanium valves and springs)
adj cam gears
spoon chip for ecu
70mm throttle body
obx-r type r style intake manifold
aem cold air intake
headers full 3" stainless catback exhaust
aem light weight pulleys including underdrive pulley
also i am swithing the b20 fuel rail and injectors over to the b18
SO MY QUESTIONS-
1)is it safe to use the p30 b16 pistons in the b18 block and using the stock rods from the ls?will there be any mods required?
2)any suggestions on how to set my cams? intake degrees? exhaust degrees?
3)my buddy told me to use the type r crank combined with the b16 pistons with the ls rods and its like a stroker motor, is this true? if it is would that be safe to do and would there be mods that would have to be made?
b18b1 block
adj cam gears
spoon chip for ecu
70mm throttle body
aem cold air intake
SO MY QUESTIONS-
