wiring harness
rex187
im a little confused about the wiring harness. do i need to cut the plugs off the wirin harness that came with the b16 and put the on the si wiring harness or do i just use the wiring harness that came on my 91 si.can some one help me?
[post=482110]Quoted post[/post]​
use the Si engine harness (everything plugs in) and add wires for VTEC
alright thanks...but thers a problem with my si harness thers one plug that dosnt match up what sould i do? should i cut it off of the b16 harness and use it?
[post=482688]Quoted post[/post]​
What plug is it?
is it for the knock sensor?
i think i got it sorted out. i think its the knock sensor. but the plug i was talking about was just under the intake manifold. it not the one with the rubber boot on it.
for the 91 si wiring i hear you need to modify or lengthen a wire or something? but i kno it plugs right in with that exception, but i don't know which whire needs lengthening? can you add to this?
i have a 91 si and it is 1.6L, and i want to dropp a b18b, what i am confused on is the wiring part i hear i must straightne one wire or lengthen it but , does anyone know this one?
