Speedracer228
I have come across a problem i have not yet been able to diagnose...
To set up the problem, 2 weeks ago one really cold night one of my heater core inlet/outlet hoses cracked and sprung a huge leak..... I replaced the hose and then refilled the system...
On to the symptoms:
-No pressure AT ALL in the system, i can squeeze the rad hoses shut when completely warm
-every 15-20 miles i have to refill the coolant up ( saabs dont have a direct fill on the radatior, the pressurized cap is on the overflow tank which is what is dropping around 3-4" every 15-20 miles)
My little fill coolant light on the info display comes up and its low again
-it only drops while running, it stays normal while off
-there is NO visible leaks that i have found anywhere
-No coolant in the oil, no oil in the coolant, no white smoke to suggest head gasket
Its been like this for a week and a half, temperature never is abnormal, never overheats, i just lose coolant and i dont know where too. If anyone has any ideas let me know i am friggin stumped!
On to the symptoms:
