H22a
grndmstr16
Can u fit an h22a in a 92 accord or 2000 ford focus.....?
Not sure if this is the right section......?
it will drop right in the accord you can even use the stock accord tranny if you wonted to, as for the ford im sure it will fit with a welder and a tourch
and probably a few trips to radioshack for some wire to help with the nightmare that will probably show up when you try to hook it up.
For the Accord, yes, it will drop right in, you can even use the stock mounts and transmission. As for the Focus...why??? I mean I'm sure you can actually fit in the engine bay with some customizing but it's not going to bolt up to the Ford transmission, so that means even more customizing to mount the H22 tranny, plus the wiring will be a nightmare.
I'd say forget it on the Focus idea, way more trouble and money than it will be worth.
Im tryin to build a rally car...... using a focus...
If ur gonna talk about the focus i started a thread under other vehicle disscusion for it....
thank u all so much for the info youve provided me
