Keep your stock engine harness and buy an obd2a - obd1 jumper harness. Make sure you have an obd1 distributor and an obd1 ecu. The best ecu for that would be an obd1 p72, since it is the ecu that comes with the engine. Keep in mind, you will need to wire in the knock if you run an unchipped obd1 ecu.
