engine?
Damm
stolen engine or what?
BigDaddyJC;990452]Did my LS B18 swap in my 90 Civic DX hatch this weekend. I used 89 model Integra axles since my car is already lowered 1.5". I also had to put in 90 model Integra spindles/rotors/calipers since my car apparently was originally a 4 speed. Its all good now though cause I got the larger front calipers in the process too to help slow me down....
Too bad I had to sacrifice my just newly aquired VX 13" rims since they no longer fit the front due to the larger calipers.....
Make sure your hatch is a factory 5 speed or you will need the Teg front spindles also for the axles to fit the wheel bearing splines.
On the axles, from what I have read, the 90-91 Teg axles will work OK until you lower the car, then they put extra outward pressure against your front wheel bearings and make them wear out much faster. If you plan to lower the car, you might want to get that done first before you spend the extra $$$ for the 90-91 axles, then have to turn around when you lower the car and buy another set of axles.....just my .02's worth though, its your decision to make.
Oh yea, if you bought some of the lifetime guarantee $150.00 Ebay steel motor mounts, then expect to have a lot of fun getting them installed and lined up properly. They are not consumer friendly designed to be an easy install........but they will work......if you have plenty of time to work with them, a large hammer, and plenty of wheel bearing grease.
We did my complete swap in 11 hrs., which includes pulling the D series motor and tranny, and pulling the 90 model Teg axles from a donor car, and would have been driving it that night if the B18 good deal engine I got had not had a blown head gasket........
I used the Integra cold air intake on mine. You will be better running the short ram kit unless you never plan to run the car when it rains. Cold Air intakes that pull up from in front of your passenger tire tend to give your motor Hydro Lock when you hit deep water during a rain storm.......
Jim C.[/quote]
