GSR cluster in my 90 civic ex
skellagher
Elder Driver
ok as the title states i need help with this cluster conversion. i have searched google for days for info but all i find are dead sites or just not the info i need. i need the wiire pin out for both the gsr cluster and the ef cluster so i can get this ish done please and thank you.
the ls,gsr, and type r cluster share the same pinouts. i put this together when i did my ls cluster swap
Cluster Lets See Them - Honda-Tech
also may prove useful for you
99-00 civic si cluster swap into 88-91 crx - Tuner-Junction
ok so u are the only one that ever gives me info i need theres a couple others too but thanks alot... but isnt there a wire from the 90-91 cluster that goes to the ecu for the speed signal? because the only reason i am doing this swap is because my ecu is throwing codes for vss but only during a deceleration like when im in 3rd slowing down say it gets down to 3000rpm and boom cel. i shut the car off and then turn it on and its gone until i slow down again. i am running a chipped ecu and i have a stock p30 chip a tuned p30 and one with 2step. the one with 2step when i put that in it stays in 2step like i have a rev limiter at 4k so i know thats an issue with vss.
if i recall there is a second yel/wht wire on the cluster plug closest to the stereo, and that wire is what runs the vss signal back to the ecu. either that or run the vss wire directly to the pin at the ecu.
