GSR cluster in my 90 civic ex
Discussion in 'HYBRID -> ED-EF / DA' started by skellagher, Mar 13, 2010.
  1. skellagher
    skellagher Elder Driver
    Newark, De
    ok as the title states i need help with this cluster conversion. i have searched google for days for info but all i find are dead sites or just not the info i need. i need the wiire pin out for both the gsr cluster and the ef cluster so i can get this ish done please and thank you.
  2. D16SiHatch
    D16SiHatch New Member
  3. skellagher
    Newark, De
    ok so u are the only one that ever gives me info i need theres a couple others too but thanks alot... but isnt there a wire from the 90-91 cluster that goes to the ecu for the speed signal? because the only reason i am doing this swap is because my ecu is throwing codes for vss but only during a deceleration like when im in 3rd slowing down say it gets down to 3000rpm and boom cel. i shut the car off and then turn it on and its gone until i slow down again. i am running a chipped ecu and i have a stock p30 chip a tuned p30 and one with 2step. the one with 2step when i put that in it stays in 2step like i have a rev limiter at 4k so i know thats an issue with vss.
  4. D16SiHatch
    if i recall there is a second yel/wht wire on the cluster plug closest to the stereo, and that wire is what runs the vss signal back to the ecu. either that or run the vss wire directly to the pin at the ecu.
