TTIWWOP
Ride: 90 z6-t hatch, 94 Bagged S10, 91 Lifted Mazda
yea, you'll need a mount kit, prelude intermediate and inner axles with integra outer axles, p13 ecu, and wiring, as well as the prelude or accord tranny
you may want a bigger accord radiator too hope this helps... __________________
I'll blow a hole in your face then go inside and sleep like a baby. |
radiator should be fine, theres a couple people around here running h22 eg with stock radiators and no problems, and they're even smaller
<u>My JDM, H22, ITR, Turbo'd Integra</u> <a href=\'http://honda-tech.com/zerothread?id=831210\' target=\'_blank\'>click here!</a> <u>project RHD sleeper hatch</u> <a href=\'http://honda-tech.com/zerothread?id=1190974\' target=\'_blank\'>click here!</a> |
Ride: RPS-13
welcome to HS
![]() i would highly not recommend this swap. if you do some research on the H22 you will come to learn that it is a pig. its a huge, heavy motor. not to mention the fact that its pitched backwards something fierce. the pitch puts a whole pile of the weight in front of the axels, which is not good. if you have a 91 teg, and money for a swap, i highly recommend keeping your LS and boosting it. An LS/T is a deadly setup. and if you have relatively low miles, you can te turbo for less than what the swap would cost. and it would be a lot more fun. __________________
-Scott (O=O/RPS 13\O=O) ....finally SR'd http://www.nissanpacific.com --- for the nissans http://www.myspace.com/SkylineScottro -- My MySpace account durrrr. |
#5 |
I concur, the H22 is not as flexible as even a B18A/B. If you want a newer motor, I would suggest a B18B from a newer Integra, like a 99+ (just for "newness") and a junkyard turbo setup. For about the same price as a B18C VTEC swap and much less than a H22 swap, you will get much more power and ALOT less hassle. The H22 is not "da bomb". It only took a year for my buddy to go thru a SC and a F Max turbo kit on his 2001 Prelude to find out how easy the H22 can fail under 7-8 PSI in less than 6000 miles. Now he is looking for a gen 2 Teg because he is fed up with the H22. Not that it is a BAD motor, it's just not the best.
| H22A in a 3rd gen (DB/DC) Integra | pissedoffsol | Swap Articles | 0 | 01-12-2004 02:17 AM |
| 1st Gen CRX FAQ's | pissedoffsol | Swap Articles | 0 | 01-12-2004 01:51 AM |
| h22a guide into a 94 integra | groundedintegra | HYBRID -> EG-EK / DC | 0 | 08-28-2003 05:18 PM |
| Is The H22a A Good Swap Idea For A Integra | PooGGles | HYBRID -> EG-EK / DC | 1 | 02-02-2003 10:01 PM |
| h22a into Integra LS | TrueStifmeister | HYBRID -> EG-EK / DC | 11 | 10-04-2002 01:19 PM |
