01 Civic - brake light problem
Discussion in 'Civic - EP, FA, FG' started by TimDroz, Aug 26, 2009.
  1. TimDroz
    TimDroz New Member
    I have an 01 Civic LX. The right brake light will not light when the brake pedal is depressed, although that bulb lights up for the running lights when the headlights are turned on (brake light won't light regardless of whether headlights are on or off). I've replaced the bulb (thought that was the original problem), but I'm at a loss for what to check next.
    Any help appreciated!
    Thanks,
    Tim
  2. mrquiggles
    mrquiggles New Member
    Earth
    hmm maybe a wiring problem? I installed a new trunk light into my care and I was wondering out why it wouldn't light up. Then I realized it was because the electric tape melted off the wiring from the heat. :D Maybe when you replaced the light bulb you moved something you shouldn't have.
  3. afmech07
    afmech07 New Member
    Did you have any luck on finding out what the problem was? i have the same issue on my 01 civic
