01 civic H motor!!!!!!
Discussion in 'HYBRID -> EP / DC5' started by goldrims, Dec 18, 2007.
  1. goldrims
    goldrims New Member
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    double post
  3. ep3moschini
    ep3moschini I R T3H NO00Bz!
    Northbridge Ma
    this swap wont work. . . lol
  4. natetiger
    natetiger New Member
    Carol Stream IL
    Its doable but its not going to be cheap. you will need the mounts, axles and some other odds and ends to do it. Also you will need to have a stronger spring rate in the front to compensate for the extra weight of the H motor.
  5. Briansol
    there are no mounts that i know of... it will need to be 100% custom fabbed.
  6. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    Too much work, IMO. Your better off putting it in the integra chassis, even then its a pain in the ass. Good luck.
  7. natetiger
    Carol Stream IL
    There are mounts, hasport makes them along with most other companies. they go for about 350 or so. Its a lot of work, but i love my H swap in the hatch, sadly im selling her. Ide say for the 01 civic or what ever its going into you will have to use normal prelude mounts and fab up the mounting points, its not going to be easy though..
  8. AHHVTEC
    Alabama
    we know there is mounts for 2000 and below civic, b was saying for the 01 there are no mounts for a h motor
  9. natetiger
    Carol Stream IL
    Yeah i just looked today and found they dont have them. All you would need to do is just snag them from a prelude and fab up mounting points. like i said.
  10. AHHVTEC
    Alabama
    just drop a k series in it and be done
  11. natetiger
    Carol Stream IL
    K series motor swaps last i looked were around 5 to 6 grand for everything and installing.
  12. 93civicracer
    93civicracer Oh, I do a little here and there.
    Texas
    Lol that's about all you got for an '01, that or just be happy with your stock motor because it will cost even more than a K to fab up a B or H series into that chassis.
    Or you could sell the '01 and get an earlier model like a '92-95, easiest to swap D, B, and H series into. Well probably the accord would be easier for an H but you get the point.
  13. FObangah
    FObangah New Member
    Richmond VA
    Build the D17.....it has potential. More low-end grunt then the older D's. Invest your money in swapping the 04 -05 front end though. The 01-03's look bugg-eyed
  14. snoopyloopy
    snoopyloopy New Member
    Killa Cali
