i've got a 01 gsr motor that im dropping into a 95 dx...i checked out my ecu harness and i have the vtec solenoid, knock sensor, and secondary intake solenoid already wired in there. but the vtec oil pressure sensor, and the evap pruge solenoid are not. i know i have to wire them in. My question is with the evap purge power...it says it needs a 12v power(hot in ON or START)..where do i get this from? im running and OBD1 p72 gsr ecu. And the vtec ground wire im assusing is already grounded?? thanks for the help.
Mike
Mike
