I have an '01 ITR hydro tranny w/ factory LSD for sale. Tranny has some issues that need some attention:
1. Slight grind going into 3rd gear, only at HIGH rpm
2. It has a problem with the gear lever where it causes a lot of play in the shifter when in gear. It stays in gear, but there is play in the actuall shifter. This has recently caused the tranny to not engage 4th or 5th gear. I ASSURE you the gears are fine, there is just a problem with the shift arm on the tranny.
3. Has a couple stripped bolt holes on the bottom of the tranny where it bolts to the motor. It is secure now, and can be secured no problem, but a couple holes are partially stripped. A helicoil will fix it right up.
$ Make offer $
$ Make offer $
