03 sonoma 4x4 howl noise
Discussion in 'Other Vehicle Discussions' started by monty92, Nov 1, 2009.
  1. monty92
    monty92 New Member
    regina, sask
    anyone know anything about a noise coming from the front end well in 4x4 mostly when turning at lower speeds. any ideas about what it could be.
    03 sonoma 4.3l 4x4
  2. 92stoccord
    92stoccord Big Member VIP
    Salem, Ohio
    Wheel bearing?
  3. monty92
    monty92 New Member
    regina, sask
    i had it on a hoist and had a stethascope to the front end and it sounds from the half shaft has minor noise but ive been told that the solenoid for the ft diff could cause a noise. just wondering if anyone has heard of this issue. or experienced it
  4. GlassHeadlights
    Calgary, AB
    :werd: I know for a FACT the wheel bearings are bad in thoes. I'd look there first.
  5. monty92
    monty92 New Member
    regina, sask
    ive checked them tho. and its only when its in 4x4. the wheel bearings would be a constant noise would they not?
  6. TurboMirage
    depends on the actual load on them. under power they would be loaded more.
  7. tblad2010
    tblad2010 New Member
    u joints??? maybe one of the hubs is starting to go bad? my dad has a ford ranger and before he switched the hubs they would make an awful noisee when in 4 wheel drive
  8. monty92
    monty92 New Member
    regina, sask
    yah im just trying to get ideas cause ive also been told its the solenoid in the front different
