1.5 V-tec, Or Plain 1.5
Discussion in 'HYBRID -> EG-EK / DC' started by hotboy445566, Jan 12, 2003.
  1. hotboy445566
    hotboy445566 Junior Member
    My question is what are the ups and downs of a 1.5 vtec, compared to a plain 1.5. Whichever one i get, it will be going into a 94 civic hatchback. Thanks a bunch for all the help.
  2. SolReaver
    SolReaver Senior Member
    They both suck
    Get a REAL motor- gsr, b16a, ls, type r, h22
    To answer your question though- the d15b7 is a POS and it has 102 hp. The jdm spec d15b is also a POS, but has a little more power at 130 hp.
  3. spoonhatch
    spoonhatch Member
    ahahahahahah....
    don't give him that much grief, some people are on a budget when doing swaps. but doesn't the hatch already come with a d15 non v-tec, and if its a si then you get the single overhead cam v-tec. so if ur gonna choose between the 2 go v-tec, at least its some what of an upgrade :rolleyes:
  4. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    the si had the d16z6, a SOHC 1.6 liter vtec engine that basicly is a peice of shit, (I have a POS under my hood.) Dont do that swap, it is a waste of money and you will not be satisfide (sp?) Save up your money. If your on a budget get the B18B, lots of trq and not that expensive.
  5. SleEPeR_CRX
    SleEPeR_CRX Senior Member
    Vancouver B.C. canada
    dude, if ur on a budget, dont get a 1.5l engine its a waist of money. Get a Sohc Vtec. or if u want a better engine go with a b18b. b18b will b about 1800 total. very inexpensive as swaps go, and will cost around the same as the lame 1.5L
  6. hotboy445566
    im not saving up to get a swap, and if i was i would get a b-16 sir II. the reason i was asking is because i have my pick of a hb with a 1.5 v-tec, or a hb with jus a plain 1.5.
  7. SolReaver
    Youre getting a car from japan? Thats the only place where the vtec 1.5 came in a car stock. And if the d15b is already been swapped in the car, dont buy that one cause the person who owned it is retarded.
  8. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    No,the 92-95 vx in the states came with a vtec-e D15Z1,and the cx came with the non vtec D15B8.
  9. SolReaver
    oops, thanks for correcting that man!
    I totally forgot about that one, but its as worthless as the rest of them :)
  10. xj0hnx
    C.C.TX.
    :D Unfortunatly your absolutely right about it being worthless.But because they are baseline,they are light and ready to be made into monsters :D
  11. asmallsol
    if your looking to buy one, the VX or the 1.5 Vtec is the best hatch to buy
    a. because they are the lightest of all the hatches
    b. they are pre-wired for VTEC (makes swaps much easier)
    c. they already have a tach
    if you are stuck between buying a vx and a non vx hatch for the same price, for sure go with the VX. The only other one that is great for swaps is the SI because it has VTEC and rear disc brakes, but they are heavier than anyother hatch
  12. xj0hnx
    C.C.TX.
    The vx is the 1.5 vtec. :D
  13. asmallsol
    i know that i should have said vx/1.5L VTEC
