Here is the deal, about five and a half weeks ago I performed a swap on my 97 del sol. I pulled the D16Y7 and replaced it with a B16A2. Engine is in, used harness that came on engine, turned the key, no fuel pump, no spark, and the speedometer jumps to 40. Starter does turn engine over, but has nothing to burn and nothing to ignite it with. I've swapped engine harnesses and mapped the one from my D16Y7 to work correctly with this motor plugged it all up, same problem. I checked the distributor and coil. Same problem. I replaced the main relay. No change. I swapped the P28 back out with the old ECU, no change. I've checked all the fuses and grounds...all good. Still no fuel or spark. And still the same speedometer problem. I'm at my wit's end. All of my local consultants I talk to have begun running out of suggestions. I'll give $100 to the first person who tells me how to fix it. As long as their suggestion makes the car run.
