1989 Acura Integra LS , I tried for over an hour to get the (harmonic ballencer )crankshaft pulley off one at the u-pull it used auto parts, before giving up. So how do you get the nut to turn, and keep the pulley from turning. We tried bolts, and clamps and other things. Someone before us tried to get if off, and left behind 4 broken screw drivers. So what gives. It is not the crankshaft pulley that has the square holding inset, like some of the other Honda and Acura have. It is round. The pulley on mine is broken, and the power steering part is broken. Is there a interchangeable one that will work ? Or how can I get the part off the wrecked car ? Engine is 1.6 L, 4 cyl, Manual 5-spd. Thanks
