1993 civic swap motor not level
aaronr
Have a 1993 civic was auto, swapped a 1994 integra b18 5 speed used the integra motor mounts. car runs but the motor is about 1 to 1.5 inches higher on the tranny side.. Any suggestion
Thanks Aaron
Did you use a manual upper tranny mount?
the auto's have a different one
I'm pretty sure you have to use the mount (the part w/the rubber in it) from an EG w/a manual tranny and the bracket (the part that bolts to the top of the trans) from the Integra
Double check, but I'm 98% sure
gah...I knew the mount was different, but I didn't think it was *that* different
sux0rz
