1994 Del Sol VTEC Race Car for sale
Discussion in 'Vehicles: For Sale/Trade/Wanted' started by B16, Feb 24, 2012.
  1. B16
    B16 Super Moderator VIP
    yay area, CA
    1994 Honda Del Sol VTEC
    Located in East Bay Area, CA
    Contact Mike via PM to me here or email at (mikeoutland@hotmail.com)
    $9,000 obo
    Chassis:
    180k miles on chassis
    Some dents in side
    New Maaco paint job from 3 years ago
    Some rust, was an east coast car. Most rusted parts have been replaced/removed.
    Roll cage (does not currently have door bars)
    Sparco Evo Seat on drivers side (build date 05/06)
    Corbeau Seat on passenger side
    Gforce 6 point camlock harness on drivers side (Expired last year)
    Gforce 6 point latch harness on passenger side (Expires this year)
    NRG Quick release
    NRG suede steering wheel
    Broadview convex mirror.
    Battery kill switch (not yet wired up)
    Hotlap timer mounted in car
    Engine (Currently tuned for E85, 199whp) ~300 miles on fresh build (new pistons, rings, bearings, hone, etc):
    B18C (was a Type R)
    B18C1 crank shaft (original R crank will also go with it, journal needs new polish)
    81.5mm OS PCT (CTR) pistons (non-oem make)
    B18CR head
    Blox HSL cams
    Skunk2 cam gears
    Skunk2 springs and retainers
    OE Type R intake manifold
    RC 440cc injectors
    Homemade 3" CAI
    DTR Narrow copy header
    3" x 18" resonator
    3" exhaust piping
    3" Magnaflow muffler
    Hondata S200
    Walboro 255lph fuel pump
    Oil press, Oil temp and water temp guages
    MFactory external oil cooler
    Morroso 5.5qt baffled oil pan
    Integra full width radiator
    FAL slim fan
    Transmission:
    Original B16A3 trans that came with the car
    New synchros about 4 years ago
    4.7 Final Drive
    KAAZ Type R sized clutch diff.
    ACT street clutch
    ACT lightend flywheel
    New master and slave cyl's
    Suspension:
    JRZ RS coilovers w/modified tien top hats
    Hyperco 800/900lb springs
    Hard Race rear lower control arms (Spherical)
    PCI offset spherical RTA bushing
    Blox rear camber kit
    No-name rear toe aduster (OE toe aduster non functional)
    ASR rear subframe brace
    22mm Type R rear swaybar
    Front LCA's with spherical bearings
    Front skunk2 pro series camber kit
    Stock front swaybar.
    Brakes:
    New 15/16" MC
    Rear OE
    Front GSR calipers
    Braided lines all around
    Wheels:
    4x 15x7 Rota slipsreams (black) with worn 225/45/15 Hankook C51's
    4x 15x6.5 Konig's (Don't remember the model) with 205/50/15 Hossier wets still mounted on them.
    2x 10mm wheel spacers
    Spares:
    Box full of nuts and bolts
    B16A3 short block block all OE, rods, pistons, etc. Still assembled and in good condition.
    B16A3 head (OE springs, retainers,cams) Broken exhaust stud needs to be extracted.
    CTR Cams
    Type R springs/retainers
    Golden Eagle cam gears
    OE oil pan
    OE Type r trans brace
    OE Type R crank (journal #1 needs re-polish, maybe repair, spun rod bearing in the past)
    ATS/Carbonetics LSD (In need of rebuild, new clutch plates. Can go metal or carbon from Carbonetics)
  2. eg6sir
    Nooooooo... moving onto bigger/better things? S2k?
  3. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    Done with Hondas for now?
  4. Matts96HB
    Matts96HB . Moderator VIP
    $10 says his new project is pictured in this thread...
    GLWS :)
    edit: I'd be interested in the spare b16 head if you decided to part it out.
  5. Faramire
    Faramire Member
    IF only you were in NJ!! :D
  6. B16
    yay area, CA
    I will ship!
  7. B16
    yay area, CA
    I should update my thread.
    Recently installed a new 6puck Competition Clutch and flywheel.
