1994 honda accord h22 swap question
PosDnus
i plan on buying the swap from hmotorsonline, i want to have power steering what all do i need to do, thanks in advance
:huh: Um...hook it up?
Seriously, H22 into an Accord is one of the easiest swaps out there. You can just reuse the Accord's A/C compressor and all the lines. Just hook it up to the new motor and you're good to go. That's all there is to it.
EDIT: Ah crap, sorry, I'm stupid. I gave you instructions for retaining the A/C. You want to know about the power steering...
Anyway, the power steering is pretty simple as well. Use the H22's power steering bracket. The Prelude's power-steering pressure line is slightly different than the Accord's, so you'll need to cut the end off of the Accord's line and then replace it with an H22/H23 piece in order to get it to attach. You could try using hose clamps, but I sure as hell wouldn't recommend it. I'd have the new end TIG-welded in place for good measure.
Do some searching on the net. Somebody out there probably makes a kit for this.
